    Results 1 to 13 of 13
      Nov 2009
      New York
      Firewall Steel question
      Hello Guys getting ready to cleanup and skin the firewall on my 69. I will be going over the old one. What gauge are you guys using, 16 18 20? Also, I'm sure it is cold rolled?
      John
      Aug 2008
      jacksonville,fl
      I decided to use some 3003h-14 alum .063 sheet for my fender/underhood sheetmetal instead of the 20 gauge steel I originally bought for the project.It,s quite a bit lighter. for steel 20 ga should be good.
      Oct 2008
      Durham,NC
      I perfer cutting it out and using 18 gauge myself
      Ramona, Ca. San Diego area
      18 is easier to weld with out burning through. 16 is better but over kill and heaver
      67 Camaro convertible (Jinx)
      Nov 2009
      New York
      May 2002
      Northern California
      i like 18g cold rolled too
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Aug 2006
      Vinland Kansas,66006
      18ga. cold roll works best.
      Atlanta, GA
      I used 16 ga., but I cut out the old and replaced the whole thing. Less heat warpage, or opportunity to "oil can".
      Dave
      1972 Nova
      1967 RS/SS Camaro - current project
      Nov 2009
      New York
      Thank You guys I ordered a sheet of 18ga. One more question what did you guys do about the VIN plate?
      John
      Oct 2008
      Durham,NC
      Mine was fine where it was on the Chevelle. Good choice on the metal.
      Oct 2009
      New Derry, PA
      If you are going to cover it, cut a window that shows the entire plate, and lap weld around it. As long as the original star rivets are visible, you shouldn't have any problems with "the man"...
      Jun 2009
      Piqua, Oh
      The tag on the firewall is just a trim tag. Your VIN is on the dash. Since you're smoothing the fire wall, you are not concerned about originality. Just remove it. (You might want to keep it, in case you ever want to go back)
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
      Nov 2009
      New York
