- Dec 2005
- SE,PA
- 41
I do a lot of rears so i usually just make a solid spacer smaller then look in my bin for shims then go from there. If you measure the crush sleeve then attmept to make a sold spacer from that it will be hit or miss if the preload is correct. Best bet there is to make it a little big then start taking a couple of thousands off at a time till you gett it right.
