Results 1 to 17 of 17
11-02-2011 #1
Converter for autocross / road race and cruisng
I am currently building a 71 chevelle with a 408 ls3, 229/236 at .050, .624/.611 lift on 112 lobe sep, 11 to 1 compression, gm single plane intake, 1200 cfm 4bbl throttle body, ls1 computer and tuning by me. I am also building my own custom wiring harness. I was going to use a T56 and still may if the budget allows. I have already mocked up a t56 in the car with the location of the engine.
I have a 4l60e laying in the garage that I could build for the car if the budget gets too tight. I used to be into drag racing before I got into the pro touring scene so I have alot of experience with automatics. I have built numerous 4l60s and I can easly build the one I already have to handle the power my 408 is going to lay down. I use rebuild kits from pro-built automatics for my autos. I would be building this 4l60e with manual shift, engine braking capabilities, GM hardened shell and 4l65 planets. I would also be using my secret sauce trans fluid, John Deere Hy-gard hydrualic fluid.
So my question is what converter are guys using for automatics used in autocross and road racing? The power band of the cam is 2400-7000 rpm in a stock displacement ls3 so probably 2200-6800 in my 408. I was thinking around a 2400 rpm converter but I am unsure of torque multiplication factor and some other factors such as diameter, lock up / non lock up. This car will also be used for cruises like the hot rod power tour and pro touring runs. So the car has to be driveable and reliable. Just most people use manuals in their pro-touring cars so I'm not sure about the auto. I just blew my budget on all new suspension, ats spindles and brakes. I can build my auto with converter for around 1200 bucks and the t56 will be quite a bit more to finsih as I do not have clutch pedal, master cylinder, slave cylinder, hose, mount, flywheel, clutch set and the t56 still needs rebuilt. So I figured around 1500 to 2000 for the t56. Thanks for any help guys.
BTW here is my build thread
https://www.pro-touring.com/showthre...X-build-thread
