Thread: 63 ChevII
10-28-2011 #1
New to Pro-Touring
- Jan 2011
- 4
63 ChevII
Owned for over 2 years, It weighs 3020 lb. The engine is a crate 572ci 620hp. Turbo 400 mated to a Gear venders Overdrive unit. Its a hoot to drive and can lay a strip of posi like you can,t believe. I did run it once 10.91 at 126. A few weeks later I found out the throttle cable was out of adjustment and only opening 3/4 of the way. Rear ratio is 4.11 . The frontend is Heits w/12in Wilwood disc. Rear is a 4 Link and a Ford 9in with G-Body disc brakes. It has the stance to be a Pro-Touring car but its more just street bully. Gagues are custom and all work. Rear tires are M&H 390/45 15in. Hope you like.
