Results 1 to 11 of 11
Thread: TBI Chevy PU has me stumped!!!
I have a 1995 Chevy 1/2T 2wd 305/4L60E and I cannot figure out what is wrong with it. When I take off from a dead stop at 1/4 to 1/2 throttle it tries to stumble and hesitates coughing and sputtering all the way up to highway speed. If I mash it it still sputters, but not as bad. Sometimes when I pull up to a stop sign it will idle down to about 500rpm and die, but it starts right back up. It sometimes throws a code for an oxygen sensor but most of the time there is no code, the check engine light will come on but it will not store any codes. When I try to check the codes it only flashes code 12 which means it is retrieving codes, but nothing after that.
I have replaced the oxygen sensor,EGR valve,throttle position sensor,idle air control motor and rebuilt the throttle body. I have ran fuel system cleaner and heet through it several times and I cannot find any vacuum leaks and somedays the problem is worse than others. Oh yeah, this has been going on for about 6 months so I know it's not just bad gas, I don't want to keep throwing money at it, so any ideas or suggestions would be helpful.
1968 Chevy II Nova
no go, no show
07-01-2005 #2
New to Pro-Touring
- Apr 2005
- 20
i have a 92 1 ton van that i use for work. i had similar probs. crazy thing is i put a new ignition module in it and it fixed it. i always thought once those buggers went bad the car wouldn't run at all. i wish there was a way to check the fuel pressure in these things, couse that could be another suspect. kinda like not enough fuel press the excelorator pump effect wont happen (hence the stumble no power upon aceloration)
i might be way off on this one just thought i'd throw in my .02
07-01-2005 #3
Full Blown G-Machiner
- Nov 2004
- Roanoke, VA
- 515
How many miles on this rig? FI is very sensitive to a stopped up fuel filter and most ppl neglect to change them so if its got more than ~40k on the fuel filter it needs to be changed.
The MAP sensor on these engines is EXTREMELY important so make sure its providing the correct signal. If its bad/flakey the ECM freaks out and drivability goes in the toilet. The CTS (coolant temprature sensor) is also just as important as the MAP and a flakey temp sensor will cause the same issues. Basically the coolant temp and MAP sensors MUST be operating correctly for the FI system to work as it should on speed density motors.
BTW, speaking of sensors... Youve replace a few as well as the IAC but what brand replacements did you use? Ive got a box full of chain store IACs, MAPs, O2s, ign moduels, etc that were brand new out of the box and they were bad so nothing but AC Delco stuff gets installed in my garage. I learned that a long time ago the hard way.
How many miles on the ignition components? I agree that an ignition module is either bad or good (only ONE time have I seen different) what about the secondary side of the ignition? How old are the plug wires and what brand are they? High mile or el cheapo plugs/wires are not saving you any money in the long run and can cause you to go insane trying to find out why an engine wont run correctly. Same deal with the cap/rotor too. High mile/cheap stuff here is just asking for issues. The secondary (high voltage) side of the ignition gets AC Delco stuff exclusively in my garage (yep, I learned this one the hard way too).
Anyways, speed density motors are pretty simple and reliable as a rock but you have to feed it quality parts as well as feeding the ECM the right signals. If all of that is up to spec then its the fuel delivery side which could be anything from a dirty filter to a fuel pump on its way out (BTW, in tank GM fuel pumps are on borrowed time by about 80k miles...especially if the tank is ran below 1/4 full a lot).
HTHGMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
#614 11.9 @ 113
New stuff finished 08/06:
4L80E trans w/TCI PCM
Syclone
Tow rig
07-01-2005 #4Thanks guys, I have a fuel filter and a MAP sensor in the garage actually. I had thought about that stuff but not the coolant temp. sensor. As for the truck it has 143,000 and the ignition stuff (Auto zone mostly Wells stuff) has about 15,000 miles on it. The fuel press. regulator diaphragm looked good last weekend when I rebuilt the throttle body. I replaced the ign. module about a month ago, by the way
1968 Chevy II Nova
no go, no show
07-01-2005 #5
Originally Posted by novaman_68
is it a delco???
is it worse hot or cold?
do you have a scan tool?
--ect readings *f
--block learn 128+/-10
--o2 sensor min/max volts
--map/baro volts
i think we are all getting this hint by now. sounds like a clasic clogged fuel filter and/or bad plug wires. my pump has @ 191k miles on it and still works great - knock on wood. i would replace all the zone parts with delco stuff though.
when the module went out in my truck i could drive @ 10 miles and it was a clean kill on accel/steady cruise.
the fuel psi can be checked with the filter removed. pep boys sells a fuel psi gauge kit that comes with an adapter for gm tbi vehicles, and otc has an adapter that replaces the fule filter with a port in the side of it. both run @ $40-50.POLITICIANS & DIAPERS BOTH NEED TO BE CHANGED, AND FOR THE SAME REASON!
07-06-2005 #6
- Aug 2003
- Byhalia, MS
- 656
