    Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
    Results 81 to 100 of 151
    1. #81
      Sep 2012
      keep it coming!!!
    2. #82
      Nov 2009
      Country Flag: Argentina
      Blev keep at it. Thank you for the LS3 intake.
    3. #83
      Oct 2010
      Longwood, FL
      crispy lines... lovin it!
      project 72 chevelle rs1
      Used to be known as streetmetal
    4. #84
      Oct 2012
      MAYODAN,NC
      I cant wait to see finished car. my heart is already skipping a beat
    5. #85
      Oct 2011
      Quote Originally Posted by zipsimons View Post
      Thank you!
      Making sure it all looks right
      before each next step is super important
      to me on this car.
    6. #86
      Oct 2011
      Quote Originally Posted by ff5013 View Post
      Thanks for the comment!
      Car has many surprises not seen here.
      Want it to be one of a kind, at least for a little while.
      Just bought a forged LS3 from Katech. Felt it was good insurance
      since I will be strapping an Eforce on it.
      Have my stock LS3 sold to another forum member.
    7. #87
      Oct 2011
      Started working on the firewall. Applied Lizardskin. New subframe installed. Front suspension is almost done.
      Welding in BMR subframe connectors.
      Should have powdercoated the Ride Tech spindles before install.
      They developed surface rust just sitting in the shop.
      Removed them and powdercoated them black.
    8. #88
      Oct 2011
    9. #89
      Feb 2006
      Arizona, Phoenix area
      great project....need to know how the lizard skin went on and are you happy with it...?
    10. #90
      Oct 2011
      Quote Originally Posted by TonyV View Post
      The guy that applied it said it was easy to spray. I purchased the Lizardkin application kit to help things along.
      To me, it made a huge improvement over the way the underbody looked. I am very happy with it.
      We did quite a bit of work to make sure the bottom of the car would look great before spraying it,
      including using panel bond on all seams. The car was stripped of all components,brackets, clips,etc. before spraying.
      We also sprayed it with the subframe removed. I feel prep is 99% of what will make this application look good.
      It looks much better than bedliner and should make a huge improvement as far as the noise level of the vehicle.
      Will be spraying the interior with Lizardskin ceramic insulation early next week.
    11. #91
      Feb 2006
      good to know....i'm still on the rotisserie but plan on shooting it here in about a month...been working on prep as you said can't do enough. I also plan on shooting it with a single stage ureathane. How much did you use ........i bought 6Ga of the sound deadner and 4 Ga of the ceramic....?
    12. #92
      Oct 2011
      I used 4 gal sound control so far. Probably will use the same on CI.
    13. #93
      Oct 2011
      Rear Seat is in!
      Mike's Custom Cars made this happen!
      Very impressed with it!!
    14. #94
      Vincennes, IN
      Very Nice Build! keep it up!
    15. #95
      Maryville, TN
      VERY nice man!
      Dan
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
    16. #96
      Oct 2011
      Quote Originally Posted by WICKED_SS View Post
      Thank you!
    17. #97
      Oct 2011
      Quote Originally Posted by 67SSDan View Post
      VERY nice man!
      Dan
      Much appreciated!
      Car is having the firewall painted as we speak.
      Will be in mechanics after that. Starting with all new wiring.
      Decided to install all mechanics before paint, as I want to
      avoid any damage to the final paint. Shouldnt be long now!
    18. #98
      Nice build! Top shelf pics.
      I have sprayed my 69 Camaro inside and out with Lizzard skin SD and Ceramic insulation. I have been told that it needs to be covered in a coat of paint (on the underside) to protect it from the elements. Mine is not on the road yet but I can't wait to see how effective the lizzard skin really is.
      I have also covered the inside with a half inch thick layer of foam sound insulator sheet where I could. I am aiming for as close to modern OEM sound levels as possible.
    19. #99
      Oct 2011
      Car is at Sweedens Paint and Body in Garden Ridge Tx getting firewall smoothed and painted before major mechanical is started.
      Finally, the fun begins!
    20. #100
      May 2002
      Northern California
      Quote Originally Posted by Blevinator View Post
      looks good but make sure they pull the sway bar and flip it over before they drop the engine in.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
