    Results 1 to 8 of 8
      May 2007
      Consider a Run To The Summit - Summit Point, WV
      Would there be enough interest to do a 'Run To The Summit' at Summit Point next Spring, Summer or Fall?
      There seem to be plenty of members in the mid-Atlantic area.
      How do the RTT... events get set up?
      Summit Point - http://www.summitpoint-raceway.com/i...id=16&Itemid=6 - has 4 tracks to rent/select from.
      Summit Point Main - Big, high speed track - 2 miles, 10 turns
      Shenandoah Circuit - Long, medium speed, lots of corners - 2.2 miles, 22 turns
      Jefferson Circuit - small, low speed track
      Washington Circuit - Autocross course
      BSR, that runs the track considered a Vintage Track day last year, but it never got much traction - http://www.summitpoint-raceway.com/i...atid=10&id=832
      Thanks,
      Tim
      '65 2+2
      347 - RetroTek EFI - 471 fwhp
      JBA shorty's, 2.5" tubes, Dr Gas X-pipe
      T-5 world class 5 speed, w/ .80 OD
      9" with 3.70's & T-loc
      4 wheel disc brakes
      17" Torq-Thrust D's, 225/45 & 245/45
      TCP/Global West suspension
      OpenTracker roller spring perches
      subframe connectors, Traction Masters, Panhard bar
      TCP manual rack & pinion
      power windows & power door locks w/ keyless entry
      Jun 2009
      Piqua, Oh
      You should contact Bill Howell. He runs all of the "Run To" events.
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
      May 2007
      Thanks, I sent Bill a PM.
      Tim
      '65 2+2
      4 wheel disc brakes
      I would go if it is in the spring... after that its back to sea duty for me and boat schedules always have a way of conflicting with things.
      Aug 2008
      Pgh, PA
      I think this venue would be absolutely great! It would be by far the closest venue to me of anything out there, there are plenty of options with the different courses, and for a RTTX format, there's some beautiful countryside for a cruise on Friday.
      '66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
      May 2007
      Anyone else in the Mid-Atlantic area that would be up for an event at Summit Point, West Virginia? It's about 1 hour and 15 minutes from the DC beltway.
      Tim
      '65 2+2
      4 wheel disc brakes
      Woodbine, MD
      I have thought about setting up an event up there as well. I have raced there numerous times at track days and with the SCCA.
      Tim...we should put our heads together and get this event rolling. I cannot tell you how many times I have thought about this and talked to my buddies about the idea. I just didnt know where to start...and I guess this is it!! I attended three RTT events this year and am very familiar with the layout of the events. If done right this could be an amazing event.
      LET'S DO THIS!!!!
      btw...since there is already a RTTS...maybe it should be "Run To The Point". That's what I have been thinking.
      Douglas Lutes
      1988 Monte Carlo SS
      Fredericksburg, VA.
      I have raced go-karts on the big track at Summint Point, it is a nice facility and they have added a number of improvements since my last visit. I would be up for "RTTP" but Dust Off is probably two years out before it would be able to participate. If however, you need volunteers to help running an event let me know.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
