Results 1 to 10 of 10
- Jun 2008
- Arizona
- 6
1987 cutless LS 1 swap complete- looking for suspension help.
I have a 1987 Olds Cutless that was a v6 car. Converted a 2000 Chevy 5.3 motor into a LS 1 style. Luanti cams and spring, larger 202 valves, stage one ported stock head, pacesetter long tube headers, professional products rails and regulator, ARP rod bolts etc. Built a mild turbo 350 with a 2800 stall converter due to my budget. I used a Buick turbo 3.8 fuel sending unit and cleaned the tank really good.
I have a 8.5 10 bolt rear end I was thinking about modifying. Axles and a 4:11 gear. I have not done suspension work and need a little help on a kit, or a mixture of parts that will help me get a low stance and still be able to work corners. I plan on a 17x11 with 315s in back. Going to notch in the frame and make a min-tub or buy a in-expensive kit. I want to use Crager SS 2 piece wheels, and roll the fender with Buick Regal fender flares or make a set.
I will post pictures of it current state at the end of the week. I really need some good ideas for suspension.
Thanks.
Dave.
07-20-2011 #2
- Dec 2008
- Lehigh Valley Pa
- 1,269
Welcome to the forum. Plenty of G-body guys here to help you out.
1996 Federal Cadillac hearse
1988 Eureka Chevy hearse
07-20-2011 #3
- Jun 2008
- Arizona
- 6
Thanks. Will post pictures this Friday. Got it to crank today. Just need to adjust the fuel plumbing and wire in the fan switch.
07-24-2011 #4
