    Results 1 to 8 of 8
      Nov 2004
      Colorado
      Cam Recommendations 540" BBC
      need hyraulic roller.
      GMPP large ovals
      Arizona Speed TPI with shortened runners.
      3.73 rear
      manual trans
      10.0:1 comp.
      heads flow well at .600 up.
      Nov 2003
      Paradise, Ca
      Comp Cams - 1 800 999 0853
      Lunati - 662 892 1500
      Crane - 386 258 6174
      Crower - 619 661 6477
      Isky - 323 770 0930
      -Matt
      Nov 2004
      Colorado
      Quote Originally Posted by Matt@RFR
      Isky - 323 770 0930
      Thanks, I think.
      The times I have called the cam companies they have read the catalog to me. I'm hoping that someone could offer some real world advice.
      Also the shelf grinds in the catalogs represent a small fraction of the available lobes, especially in the case of Comp cams. They have lobes for the BBC that are not represented in the catalog.
      Sep 2002
      San Jose, CA
      I have had really good luck with Crower Hyd-Roller cams in general.
      While a 540 can swallow a lot of cam, we also want to not have the revs go too high as the piston speed is pretty wild.
      For a combo like this I would be looking at something along the lines of the Crower 253HR260
      253/260@050
      .636/.659 lift
      now here is the tricky part, we are going to spread the love seperation to 114 deg to help keep the EFI happy (minimizing idle overlap).
      This should make peak power somewhere in the mid to high 5000's with a redline around 6400RPM (hyd roller lifter pump up around 6200 anyways).
      Just call me Brett
      Detroit Subs
      Cam Motion - 225-926-6110 ask for Kip
      Nov 2004
      Here's a second vote for Cam Motion. Have your head flow numbers ready to provide when you call.
      Nov 2000
      O-town
      I've heard good things on Cam Motion too,
      Ooooo, the love seperation lol,
      Comp's always wants you to change the car to meet the off the shelf cam they have,
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by EFI69Cam
      Thanks, I think.
      Call Lunati and ask for Harold. He's forgot more about grinding cams than most people will ever know. Harold's an icon in the camshaft industry and will take the time to help you choose the right grind.
      Also,there's a lot of discussion going on over at Team Chevelle about camming a 540. Good stuff and Harold is right in the middle of it.
