      Jan 2009
      San Antonio, Texas
      Rear Brakes for American Iron Car?
      Fellas -
      I have to admit that brakes are not something that I'm intimately familiar with and could use a bit of help here.
      Car is a 71 Javelin, 401, 4 sp. About 400 rwhp. Will be street driven some, but more of a track car (full cage, gutted interior, etc). Going to run 17 x 9 wheels. Rear will be a NASCAR type full floater 9" (1 deg negative camber, I think) on composite leaf springs with a panhard bar. Will start out running HPDE's, but would like to graduate to American Iron at some point.
      The folks who are building the rear will need to know what size rotors to use. I will have to source the rest of the brakes myself.
      American Iron is limited to a 14" rotor, IIRC, so I'm guessing that's what I will be using on the front. What about the rear? Is 11.5" or 12" good enough for the rear or do I need to go larger? Realize that the front brakes do most of the work, but need decent rear brakes b/c the fronts will eventually fade.
      Any recommendations on a setup that won't bust my budget?
      Thanks!
      Scott
      Check out my YouTube channel for vintage car and truck rescues and rebuilds! THE BULLETPROOF GARAGE!!! - YouTube
      Jul 2010
      Sacramento, CA
      12 inch rotors with wilwood SL4 calipers. It is the caliper that all other racing calipers compare themselves to for a reason!
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Apr 2004
      OKC, OK
      I would buy as much brake as you can afford. It is where many races are won or lost. Since you plan on racing you need to be concerned with heat disapation and rotor warpage, so the bigger the better.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by MuscleRodz View Post
      Don't you get to diminishing returns at some point? I'll have 17" wheels, so I can fit a pretty decent-sized rotor in there. Would think that rotating mass and weight would be something to stay away from. Seems like most road race folks with similar cars are running 11 3/4" or 12" brakes out back, even if they have room for more.
      Scott
