    Results 1 to 8 of 8
    Thread: KRC pump
      Nov 2009
      Ca
      KRC pump
      I was on another web site and I came across a statement about a KRC cast PS pump "I would not recommend this for a daily driver." What are your thoughts on this?
      Rustburg, Virginia
      They may be talking about the cast aluminum....the cast steel pump should be fine for daily use.
      Loganville, GA
      I would talk directly with KRC, to see what they say. Great people there, very helpful.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Auburn, WA
      I have the aluminum on mine with zero issues at all. I think the steel pump is cheaper, isn't it?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      RI
      I'm using an aluminum one with resivor bolted to it, no problems, I put about 4k miles on it with no problems so far.
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      Loganville, GA
      The steel or cast iron pump is cheaper. It does have a larger volume, 13.1 cc vs 9.2 cc for the aluminum one. There are a couple smaller volumes for the aluminum as well. At least for the old aluminum pump, they have a new aluminum coming out so the specs may change. The larger volume of the cast iron pump is the reason they are limited to 5,500 rpm pump speed.
      1975 MGB Roadster
      2003 GSX750F Katana
      Cartersville, GA
      I can't imagine why either would be a problem, especially a KRC one. The KRC stuff is very high quality, and their new stuff is going to be even better. Since the OEMS are getting away from hydraulic power steering, and the writing is on the wall for rebuildable Type II pumps, they are building their own, improved version with all new parts of their own manufacture.
      If anyone needs something from KRC, shoot me an email and I'll get you a price.
      Joe Hinds
      Rustburg, Virginia
      Quote Originally Posted by BulldawgMusclecars View Post
      Exactly. Great mfg and products
