    Results 1 to 9 of 9
      Norwalk, Ct
      Country Flag: Wales
      Carbon Fiber struts for IRS
      I bought some carbon fiber tube (good stuff from Rock West Composites) to make the spreader bar for my 69 vette. Now because I ordered a specific size the minimum amount was a 72" length...and I only needed 15"!
      So anyway I have been looking at other uses for this stuff and I am thinking about making the camber struts on the rear out of them (and expanded to the 4 link I plan on making this Winter)
      Now I have the industrial epxoy, I would be using mild steel threaded bungs you can get from Speedway, the same process I used for the spreader bar, but my main question/concern is what type of forces are applied to these struts? Theres no twisting force , so I am thinking length wise (wheel trying to move in and out) and maybe a little front to back (which would probably be taken up by the heim anyway). Anyone have any thoughts?
      Nick
      Nick Townsend
      Pro-Vintage 69 Corvette
      64 Riviera Custom - 20's, air bags
      Shell Valley Cobra
      2005 Penske Racing Dodge Charger Nextel Cup Car "Rusty's Last Round"
      St George Utah
      your braver than i am!!!!
      how good is your glue?
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Norwalk, Ct
      Country Flag: Wales
      Its Loctite 9430, its a room temp curing, two part epoxy designed for structural bonding. It also has high peel and shear strength and its also heat, oil/gas resitant.
      Nick
      Nick Townsend
      Shell Valley Cobra
      Jul 2011
      Iowa
      Can you put the inserts in with the adhesive and then roll pin through the tube and insert for extra security. My buddies are from an off road background and they always cringe when I talk about suspension components because I come from a dirt track background where I would turn a dirt late model down into the corner at a 110 mph with 5/8" aluminum tubes for trailing arms, tie-rods and strut rods with 1/2" bolts holding it all together. lol
      Just re-thought that idea, it would only work if you had longer inserts made so the roll pin didn't interfere with the rod end. duh! It's morning I guess, lol
      My Rides:
      1976 Chevrolet Silverado
      -Lowered and Shaved
      1974 Chevrolet C10
      -Project
      Auburn, WA
      There typically is a twisting force on those but if you are using heims that should be negated.
      According to the data sheet of Loctite 9430 the shear strength is only about 2000PSI. I might be missing something because that is awfully low for what you want. Have you done this before? Do you have the means to test the part in tension before use?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Feb 2006
      Idaho Falls, Id
      Thanks for the source! I just bought my old R1 back that has some damage to the seat section of the frame. I was wondering where I could get CF tubing to build a new seat frame.
      Here's the damage. I'm thinking I could weld brackets for heim joints where the square tubing is welded on and and make adjustable CF rods to replace the aluminum tubing. It'd look sweet and I could adjust my seat angle.
      Traven
      TN
      Quote Originally Posted by silver69camaro View Post
      I too looked up the data, and Assuming you had a 1.5" dia tube with a 1.5" long insert you would be looking at over 16,000 pounds. I would look for a stronger resin but it should be doable as long as the surface area of the surfaces... And definitely test first. But then, I also have access to a good sized UTM to test things like that which I know is not the norm.
      What are the specs on the tubing? and the planned inserts?
      Benjamin
      Twin Dusters
      Apr 2010
      Jersey Shore
      By 4 link, do you mean a setup that will get rid of the halfshaft as a suspension arm? If thats the case, Im not sure I would want cornering forces pulling on the glued-in rod end sleeves. No technical data to back up that thought though
      I would really like to see your plans for the 4 link if you care to share
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      san diego
      Structural adhesives are used alot in aerospace and even bicycles. I am sure you could design something to work. But I would be concerned with fatigue loads as well as limit loads. I would suggest not driving the car on the street unless you have performed these tests.
