    Results 1 to 12 of 12
      Holmes Hollow, Ontario Canada
      best spark plugs?
      I'm about the to put my ls2 in. Its only got 15k miles on it but since I'm putting headers on it I would rather replace them now. Any suggestions?
      ____________________________________________
      Scott
      Oct 2006
      McKinney, TX
      stick with delcos.
      The aftermarket's spark is usually a higher temp. While on paper it may sound good, if you are running a stock ECM, it can cause all kinds of havoc.
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Good to know.
      Scott
      May 2009
      Florida
      Ngk
      Fernando
      1967 PT Camaro
      Project "N-XSS"
      https://www.pro-touring.com/forum/sh...ad.php?t=70712
      I already ordered ACDelcos. Thanks though.
      Scott
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by killer67 View Post
      Ngk
      I usually run NGKs or OE. I pulled the GM plugs out of my 02 olds OHC 3.6 the other day..co-branded gm/ngk.
      Scott from NJ.
      Vent Windows Forever! ...
      Central Indiana
      Im running NGK plugs also Scott.... With no issues.
      Jun 2011
      Brooklyn, NY
      Another vote for NGK
      I already put the ac delcos in it. I was surprised they were over $7 a piece. I'm guessing te NGKs would have been cheaper but at this point it doesn't matter. Once I drive the wheels off it and need to change the plugs I'll try some NGKs.
      Scott
      Fullerton, CA.
      My AC Delco's are Dual Branded NGK/Delco too on the pug itself. They came out of a Delco Box.
      Mike Martin
      Heavy Chevy 2.0: 71 Heavy Chevy, Unisteer,SC&C, GW,Eibach,Bilstein,Helwig,Showwheels-Streeters, Carb'd LS-327 W-200-4R
      LS-327 powered, Atomic EFI on the way
      Huntington Beach CA.
      I personaly like to run Accel, they have always been dependable. Here is a good article on spark plug facts. http://www.carcraft.com/techarticles...ips/index.html
      -Louis
      1967 RS/SS (driver)
      1968 RS/SS (project)
      Jul 2010
      Sacramento, CA
      The best? Pulstar. Its the only plug ive ever seen that increases horsepower over NGK or AC Delco plugs. They cost $120 for a set, but they work.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
