Thread: Vintage air problem
07-24-2011 #1
- Dec 2009
- ri
- 278
Vintage air problem
My system will not switch from lower vents to any other vents, the system has worked fine for 2 months and and I tried switching from feet to defrost and nothing- blower fan still works fine- any suggestions? its a 4 lever control panel #49110-shq installed in a 65 GTO with LS1
07-24-2011 #2
- Aug 2010
- S. FL
- 70
Does your system use a test white wire that can be grounded to reset the controls to reference 0 ohms?
Greg
1969 Camaro Vert RS SS
07-24-2011 #3
- Dec 2009
- ri
- 278
well after 3 minutes of poking around I discovered a loose connection into the control module- works fine now
