    Results 1 to 10 of 10
      Austin, TX
      Think I cooked my transmission
      Any quick fixes???
      Participating in Heidts Challenge right now! If I give the car a lot of throttle is doesn't want to go anywhere. If I ease into the throttle, seems better. This is also my ride home! HELP!
      Todd Longfellow
      SoCal
      Is this an automatic transmission we're talking about?
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
      USA
      Put some of that Lucas Auto Trans Additive in it and take it easy 'till you get home ..
      Jeff Tate
      U.S.A.
      Austin, TX
      Yeah, probably should have mentioned that it was a 4L60E, but I was a little frantic at the moment... Called all over on Saturday trying to find a shop that was open with no luck. I limped to the nearest Jiffy Lube, and had them do a quick tranny fluid flush. Kinda got 1st & 2nd gear back, but not enough to drive it home. I ended up talking my brother into coming out to Joliet, about an hour from home, and trailering it back.
      Weighing my options now...
      Todd Longfellow
      May 2011
      Central FL
      Burned out the clutch packs? Did you smell the fluid before having Jiffy Lube work on it?
      - David
      1967 Camaro - In remembrance of my friend Scott
      Jun 2009
      Yep. Toast.
      Dan W
      1968 Plymouth Road Runner
      1962 Dodge Dart 440
      Austin, TX
      Pretty sure I burned out the clutch packs. Smelly and smokey. (Names of 2 new dwarves? )
      Looking into my options whether to rebuild my 4L60E with a cooler or go 4L80E. Only pushing about 380 hp/380 ft. lb. tq., so I don't think I need anything real beefy... yet.
      Todd Longfellow
      Belle Plaine, MN
      Scott Parkhurst
      Austin, TX
      Oooooh, no I haven't. Thanks!
      Todd Longfellow
      Nov 2000
      O-town
      4l60 barely hold up behind a 4 cylinder in a Sonoma truck, wrong choice in trans, modify it an add clutch packs, vette servo, "The Beast" sun shell, trans go shift kit and a cooler, might last then,
