Results 1 to 10 of 10
Yes i still have the problem.. in fact its worse.. Im only getting 2-4psi now.. ive ruled out the intercooler and bypass valve.. i ran the procharger directly to the carb and it made no difference.. the belt is very tight.. Im not hearing any belt squeel although there is some belt dust on the pulley and charger..
I really wish someone could tell me whats wrong with this damn thing.. It cant be the the unit is bad because i see no damage and my seals are not leaking..
Project JUST-N-SANE
84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
