    Page 6 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    Results 101 to 120 of 300
    1. #101
      Oct 2005
      Jasper,IN
      Quote Originally Posted by piratebaseball View Post
      So in a 17x9.5 wheel, would I need 5.25 BS or 6.25 BS...I'm a rookie when it comes to wheel/tire combos... Thanks!
      Well, on an 18x10 we use a 5.75" BS. So on a 9.5" you could stick w/ the 5.75" BS and that will give you .5" more clearance at the fender lip. May not have to modify as much....
    2. #102
      Oct 2005
      Jasper,IN
      Quote Originally Posted by DarkoNova View Post
      I do not have any pics. Sorry.
    3. #103
      Cookeville, TN
      Quote Originally Posted by darren@ridetech View Post
      ie. your results may differ.
      Darren,
      Could you get the guy that did the inner fender metal fab on the 48 hour Camaro to write us a list of steps to accomplish this feat? Most of us are not full time metal-working guys!
      Gary
      '69 Camaro - 427 SBC 526hp, 593 ft-lbs, Tremec TKO, Ridetech Coilover Suspension w/TruTurn, Billet-Specialties Draft 18x9, 18x12, BFG KDW 275/335
    4. #104
      Cookeville, TN
      Also...an important item would be the process of determining what to cut out of the fenders.
    5. #105
      Auburn, CA
      Too many questions answered with "to be determined".
      Tim Tracy
    6. #106
      Oct 2005
      Jasper,IN
      Quote Originally Posted by TT302Z28 View Post
      Well quit asking questions that I don't know the answer to yet....
      There are so many cobinations of parts being used, it's almost impossible to fit every possible combination of control arms, spindles, springs, shocks, R&P etc.... to ensure that it will work. We know for a fact that it works perfect with ridetech CoilOvers/Shockwaves, upper & lower StrongArms, ridetech Tall Spindles, our steering arms, tie rods and center link bracket. Any variation from those parts is to be determined.
    7. #107
      Indiana
      I am truly sympathetic to the guys wanting guidance on the fender modifications. I think that a step by step instruction sheet of precisely how to accomplish the modifications to the inner/outer fender on a 67/68 Camaro to fit the 10" wide wheel would be great.
      It would also be a little unfeasible...here's why.
      I can't tell you to "remove .375" of metal from an area starting 2.5" from the very bottom of the fender extending to 11" above that point". I wish I was that level of teacher. The reality is that there are many different ways to acheive tire clearance, if needed. You may not even need to do anything if you are using oem height body mounts...the 48 Hour Camaro had half height mounts. If you are using a different brand of tire you might not have any tire clearance problems.
      On the 48 Hour Camaro our metal guy Kurt took an inordinate amount of time to make this modification look invisible. He basically trimmed the outer fender lip off the car up to the first body line...about 3/8" of an inch. That provided the neccessary tire clearance at full lock. Then he trimmed away part of the inner fender that would come in contact with the tire at full lock. The amount was determined by trial and error fitting. Then he shaped an "adapter" peice that would reconnect the inner and outer fender. At that point he could have welded this new piece to the inner fender, attached it with adhesive, rivited it, or just left it out for that matter. He chose to rivit it because we were running out of time before the build.
      The inner/outer fender modifications...if even needed...are something that you likely will want to engage soeone with at least a little experience in the area of metal/paint work. Its really not that hard, but might be beyond accomplishing with an adjustable wrench and a can of wax.
      Having said all that...I'm sure that there is someone more talented that I am out there who might be able/willing to create some sort of intructional video on this subject. I am all ears [and eyes] on that!
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
    8. #108
      California
      I lol'd.
      Matt
    9. #109
      Oct 2006
      Phoenix, AZ
      There is no instruction booklet for hot rodding.
      AirRide's parts accomplish what they are intended to accomplish. It's our job as hot rodders to take care of the unexpected variables and peripheral systems and clearances that can not be foreseen my the mfr.
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
    10. #110
      So-Cal * Corona
      Preach It Jeff, I agree with you , If you want cookie cutter products then leave it stock , Thinking & Modding is what hot rodding is all about make it your own
      John
      71' Nova
    11. #111
      Oct 2005
      Jasper,IN
      We have set a deadline on the introductory price for the Complete TruTurn package of Sept. 30th. However, if purchased by Sept. 10th, you will also receive FREE SHIPPING!
    12. #112
      Cincinnati Ohio
      I have this on my car and WOW, what a change from stock spindle/steering set up.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
    13. #113
      California
      Curious as to why this wouldn't work with an AFX spindle? My car should finally be drivable within the month, and I don't mind being the guinea pig to test this out with AFX spindles...as long as I can return it if it doesn't work for some odd reason, lol.
      Matt
    14. #114
      Oct 2005
      Jasper,IN
      We have a set of AFX spindles here, but the 48 Hour Camaro has not sat still long enough to try them out. We are headed down to Bowling Green this afternoon for the LS Fest. If you want to try it out, I have no problem taking it back if it will not work. We have always been understanding when it comes to returning products.
    15. #115
      USA
      I've got a Tru Turn System coming too .
      It should be here any day now .
      Then , I'll just have to get it put on before Run thru the Hills .
      I think it will cure my bump-steer and camber gain issues ..
      Jeff Tate
      U.S.A.
    16. #116
      California
      Cool, if I get my car back together before you manage to test it with the AFX, I'll do it.
      Matt
    17. #117
      Aug 2010
      Long Island, NY
      Question for Ride Tech. If I am running a factory spindle on a '69 Nova, with a tall upper ball joint wouldn't this kit still work without the spindles (part# 11169525)? The 2in drop moves the pin on the spindle up which would technically bring the bottom of the rim closer to the tie rod, so on a non-dropped spindle the pin would locate the rim further away from the tie rod (interference would not be an issue). The tall ball joint would give you the correct spindle height for the geometry, and steering arms would bolt to factory spindles - correct? If you purchased Ride Tech spindles without the Tru Turn kit, factory steering arms would bolt on (same bolt hole and spacing) - I'm guessing. The reason I ask this is because I am happy with the ride height I have now. I would hate to start messing with spring spacers to bring it back to where it was after dropping it 2in with a new spindle. Also, wouldn't mind saving the $350 for the new 275's I'd need to get.
      Frank
      Long Island, NY
      1969 Chevy Nova - 370 LQ4/LS3, Procharger, TKO 600, 9" w/ 3.89's (always a work-in-progress)
    18. #118
      Oct 2005
      Jasper,IN
      Quote Originally Posted by 1fastssnova View Post
      Are at stock height now, or have you lowered the car w/ springs or arms?
    19. #119
      Aug 2010
      Long Island, NY
      Factory spindle, tall ball joint, SPC uppers and lowers, Global West Springs with 3/4" drop. SPC Lowers have adjustable ride height kit (http://scandc.com/new/node/672).
      Frank
      Long Island, NY
    20. #120
      Cincinnati Ohio
      Im no sales person for ridetech, but if you ditch ur front end(sell it) and start over with Ridetechs upper and lower arms, and go coilovers, and tru turn set up, you will be shocked how different the front end will be.
      I have DSE upper and lower arms(have to mod the lower) ATS upper coil over mount, ridetech single adjustable coilovers and tru turn set up and WOW, so much better then before.
