    Page 10 of 15 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 LastLast
    Results 181 to 200 of 300
    1. #181
      California
      Bump for a template to check header fitment.
      And a quick question. I've got the Hotchkis 2" drop springs, will those springs and the drop from this kit be too much?
      I love low, but I don't want to make sparks every time I go over a speedbump...
      Matt
    2. #182
      I can answer the quick question about your springs with the ridetech spindles: Yes it will be too low unless you have done mods to your fender wells. I put a 1/2" coil spring spacer under my Hotchkis coils with the ridetech spindles - it put the ride height spot on where a 245/45-17 tucks just about level with the wheel opening. I didn't have any rubbing problems on the track or autocross at RTOS. I haven't noticed any more rubbing than I already had previously except if I miss dodging a pot hole.
      GeoffP
      68 Camaro - LS1/T-56
    3. #183
      Jul 2012
      Bassett, VA
      Would you happen to have a part # for the Summit headers that will work with the tru-turn system?
    4. #184
      Cincinnati Ohio
      I have the Dynatech 1 3/4- 1 7/8 stepped headers on my small block and they clear the tru turn. They also fit the T56.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
    5. #185
      Mar 2010
      Norway
      Country Flag: Norway
      Why is there a tru turn kit for the 64-66 mustang and not for the 67-70? What is the difference?
      65 mustang HT no name
      67 mustang HT red rocket
    6. #186
      Oct 2005
      Jasper,IN
      We have had the upper and Lower StrongArms for the 67-70 Mustangs for several years. That kit did incorporate the dropped cross shaft, but it used the stock spindles and steering components.
    7. #187
      Indiana
      The Tru Turn for the earlier 64-66 Mustang incorporates the StrongArm tubular control arms [with a dropped cross shaft], a taller ridetech spindle to optimize camber gain and ackerman, and a drag link bracket that eliminates bumpsteer. The current system for the 67-70 Mustang uses the StrongArms, but interfaces with the oem Mustang spindle and makes no changes in the steering geometry. When we do the actual Tru Turn for the 67-70 Mustang it will incorporate all the extra features of the 64-66 Mustang Tru Turn system.
      Having said all that, our current StrongArm system for the 67-70 Mustang works quite well with the TCP rack system that will allow you to optimize the bumpsteer. We have not yet worked with any other rack system out there.
      My own 69 Mustang has our off the shelf StrongArm system with TA series ShockWaves and a TCP power rack. It drives and handles quite well...some might say a bit beyond that .
      The reason that we have not yet done an actual Tru Turn system for the 67-70 Mustang is that the spindle/steering arm [and aftermarket brake options] are much better than the earlier cars and do not impose the handling compromises of the earlier cars. There are improvements to be made, just not the huge ones that the earlier cars need.
      But...we will be doing an actual Tru Turn system for the 67-70 Mustang in the next 12 months. It will incorporate the ridetech spindle and steering geometry improvements of the earlier Mustang system to make those 67-70 cars even better!
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
    8. #188
      Mar 2010
      Norway
      Thank you ridetech guys
    9. #189
      USA
      Quote Originally Posted by Tony1968 View Post
      What car , what engine ???
      Jeff Tate
      U.S.A.
    10. #190
      Benicia, Ca.
      We have had major success with the Tru Turn...thanks to ridetech for putting out a great, yet simple system that makes a HUGE difference on the F bodys!!!
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
    11. #191
      Jul 2012
      Bassett, VA
      If you are running a 168 tooth flywheel the Dynatech 1 3/4" tube headers will not work. they will not clear the starter. several different 1 5/8" headers will work with a more swept back design than the super-comps.
    12. #192
      Any chance the TruTurn installed pictures can be reposted? It appears they've been pulled down. I was hoping to look them over since I'm getting pretty serious about ordering some ridetech parts very soon.
      GeoffP
    13. #193
      Cincinnati Ohio
      Quote Originally Posted by GeoffP View Post
      What kinda pic would you like to see? I have it on my car, and can get pics for you.
    14. #194
      Oct 2007
      Union Mo
      Quote Originally Posted by Bad94 View Post
      What size wheel & tire are you running?
      Thanks Eric
    15. #195
      I was looking for the pictures that ridetech had posted of the 48 Hour Camaro in this thread. I wanted to get a look at the location of the tie rod with the new steering arms to make sure my Wilwood calipers aren't going to have any clearance issues.
      GeoffP
    16. #196
      Cincinnati Ohio
      Quote Originally Posted by eric1967 View Post
      Thanks Eric
      Im running a 18x9.5 with a 275.
      I will get some pics of the steering arm for you.
    17. #197
      Aug 2009
      Napa, Ca.
      Anybody running the TT kit with Doug's 368 long tube headers? Any clearance issues?
      Jeff
      69 Camaro build, body & paint by West Coast Auto Craft
      Build thread http://www.lateral-g.net/forums/show...ght=brownstone
      Lateral-g Feature http://www.lateral-g.net/forums/showthread.php4?t=44186
      Thanks to Matt's Classic Bowties and Pro-Touring.com
    18. #198
      Thanks!
      GeoffP
    19. #199
      Benicia, Ca.
      Black friday specials on ridetech...just PM
      MCB
      Benicia, Ca. 94510
      866-628-8746
      www.mcbparts.com
    20. #200
      Dec 2011
      Elverson, PA
      I have TT with Dynatech headers on a TSP LS3 and a T56. We had to put spacers under the frame motor mounts but the headers cleared the TT. I used S&P conversion plates with energy suspension mounts. I had ATS plates but S&P plates raised the motor up more. I am running 18x9.5 wheels with 265s. I will post pics once the wheels are mounted.
