    Page 1 of 15 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 300
      Indiana
      RideTech Tru Turn System
      The 48 Hour Camaro was the testbed for this new suspension system. It has worked out extremely well, so we are now ready to release it to the world...
      Also, for a limited time, and only for Pro-touring.com menbers...ask about your special introductory pricing.
      The TruTurn Steering Package
      If you tuned in for the 48 Hour Camaro build, you probably noticed that the build team put 10" wide tires on the front and wondered how it was done. Well now the truth is out...it was all made possible by the TruTurn, a steering upgrade package brought to you by ridetech.
      What is it?
      The TruTurn system is an upgraded steering system that includes the following:
      1. Spindles - taller to improve the camber gain and a raised spindle pin to lower your car by 2"
      2. Steering Arms - designed to correct bumpsteer AND allow clearance for up to a 10" wide wheel with a 5.75" backspacing.
      3. Draglink bracket - bolts onto oem draglink to relocate the inner tierod end to minimize bumpsteer
      4. Tie Rod Assemblies - integrates with your new steering arms and centerlink to provide a tru "no fab" bolt on steering system.
      What will this system do?
      Everyone knows the early Camaro/Nova front ends have very poor suspension geometry...the tires lean outward around turns, the bumpsteer is bad, and there is little room to run a wide wheel because of the OEM steering arm interfering with the inside of the wheel. The TruTurn system resolves ALL of these issues...the tires now lean INTO the turn, the bumpsteer is UNDER .050" through 5" of suspension travel, and you now have clearance to run up to a 10" wide wheel with a 275mm tire!
      TruTurn complete package includes:
      spindles, steering arms, draglink bracket, and tie rod assemblies
      Price: $1000
      Call in and ask about an introductory price! Phone: 812.481.4787
      Vehicle Applications
      Part #
      Price
      1967-69 Camaro
      11169500
      $1000
      Buy Online
      1968-74 Nova
      11169500
      $1000
      Buy Online
      TruTurn UPGRADE package ( same as above MINUS the spindles )
      Price: $650
      Part #
      Price
      1967-69 Camaro
      11169525
      $650
      Buy Online
      1968-74 Nova
      11169525
      $650
      Buy Online
      48 Hour Camaro - Ridetech Front Suspension Video
      Related to the TruTurn, check out this front suspension overview of the 48 Hour Camaro. The video talks about the new TruTurn steering package and how it helped fit up a 10" wide wheel on the front of the car while at the same time nearly eliminating all of the bump steer.
      Also don't forget to check out the Triple Adjustable Coil-Overs being installed!
      48 Hour Camaro - Ridetech Rear Suspension Video
      Check out the AirBar set-up going in the 48 Hour Camaro - only this one isn't being built with traditional air suspension, but using the new triple adjustable coil-over shocks from RideTech!
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
  • #2
    May 2000
    Looks like a really nice system.
    Are those steering arms the same dimension as the factory "short" arms? Are parts available for individual sale?
  • #3
    Indiana
    The Steering arms are not any OEM Camaro piece. The system will be offered with spindles [$1000] , or without spindles [$650] because there are many of our current custoemrs that already have our ridetech spindles. We're not going to offer any components separately because they are designed to work as a package. To use them with other components would negate any performance or fitment benefits and probably cause you to take my name in vain!
    Bret Voelkel
  • #4
    Jul 2004
    Braselton, Ga.
    Nice setup Bret. I think this will go over very well!!! Good luck.
  • #5
    Suisun City, Ca.
    This looks like a good system, something I have been looking into. What about breaks? I have Baer 13" track system on front. Will these bolt up?
    Mike
  • #6
    Indiana
    Quote Originally Posted by mdprovee View Post
    Any aftermarket disc brake system that will fit the A body or F body GM spindle should work fine. We have specifically fit the Baer 14" rotor with their 6P calipers with a 17x10 and an 18x10 wheel and a 275mm BFG tire.
    Bret Voelkel
  • #7
    California
    So then none of it works with AFX spindles?
    Matt
  • #8
    Sep 2009
    So. Cal
    Quote Originally Posted by DarkoNova View Post
    http://www.ridetech.com/store/suspen...gm-f-body.html
    Frequently Asked Questions
    3. Can I use my existing OEM or other aftermarket dropped spindles with this system?
    No...the RideTech spindle is a critical part of the whole system. Using a different spindle will create highly unfavorable suspension geometry and would be incompatible with our steering arms.
  • #9
    Lawrenceburg, TN
    Quote Originally Posted by bret View Post
    I see that's the same pricing to public on you're website and protour members here, are any deals coming later? for members
    also do you have the tall spindle without the 2 inch drop?
  • #10
    Dec 2009
    El Dorado Hills
    I am currently using a corvette wheel up front with a 2" spacer. I am also using the Steeroids rack-n-pinion.
    Will the steering arm and spindle combination conflict with the inner wheel?
    Also, will the system work without the draglink bracket and tie rod assembly?
    Gaetano Cosentino
    Dont Drive Faster Than Your Angels Can Fly
  • #11
    May 2002
    Northern California
    Quote Originally Posted by Gitter Dun View Post
    The tie rod mount looks to be moved up quite a bit so it is near center of the rotor surface. No rim issues. The components would have to be used together to work.
    you guys been doing your homework.
    MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
  • #12
    Mar 2010
    Clovis NM, 88101
    Did I miss it? Are there any plans for the 2nd gen camaro's?
    73 Camaro
    Gene
  • #13
    Oct 2005
    Jasper,IN
    You might try hitting up one of our many dealers on this forum...
  • #14
    Oct 2005
    Jasper,IN
    We have not tried the tall spindles w/ the Steeroids Rack yet. You might check w/ them too see if they have.
    To fit a 10" wheel we had to modify the inner fender well and outer lip.
  • #15
    Auburn, CA
    Ok, how about with the "G" mod? Do you have a standard height spindle without lowering?
    Just bought the Chicane kit and the ridetech Single adjustables and can't go back to factory mounting for the uppers. I'm sure I'm not the only one who did the mod and don't need a drop spindle.
    Tim Tracy
  • #16
    Oct 2005
    Jasper,IN
    I agree, I don't think you would want to run the tall spindles along w/ the G-mod, probably too much camber gain.
    We have not yet tried it yet.
  • #17
    May 2011
    Savannah GA
    Country Flag: Mexico
    Quote Originally Posted by newmexicosaint View Post
    I'd also like this question answered.
  • #18
    Oct 2005
    Jasper,IN
    We have not looked into building a Tru Turn for the 2nd Gen yet. The Tru Turn offers 3 solutions for the 1st Gen, allows for wider tire, taller spindle for improved camber gain & virtually no bumpsteer. 2nd Gens already have a taller spindle, so that won't be necessary. We have already fit an 18" x 10" under a 2nd Gen too, so there isn't a whole lot that needs to be fixed.
  • #19
    Los Angeles, CA
    Darren,
    Could you get me a measurement from the end of the steering arm to the closest spindle bolt hole on the steering arm. I want to make a rough measurement with my wheels before I jump on this.
    Best,
    Don
  • #20
    Oct 2005
    Jasper,IN
    I don't have that information in front of me, i would have to get back w/ you. But the length of the arm only tells half of the story. Much of the wheel clearance is gained by raising the tie rod as well.
  • Page 1 of 15 1 2 3 4 5 6 11 ... LastLast
