    Results 1 to 10 of 10
      Aug 2009
      Langley BC, Canada
      Wiring a 10SI alt?
      I have a 10SI alt on my Impala and was wondering if the wire that is supposed to go to the charge light has to be connected? I do not have the factory light working as I am going to put a Autometer volt gauge in instead.
      I have the charge wire and the volt sensing wire to the main positive distribution block as per MAD electric. Just not sure where to put the idiot light wire to if anywhere?
      Kevin Freund
      1961 Impala Drop Top
      May 2002
      Northern California
      Quote Originally Posted by 61ragtop View Post
      big plug right?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Aug 2009
      Langley BC, Canada
      Nope it is the 2 wire plug like the 10SI in this link........
      http://www.madelectrical.com/electri...elcoremy.shtml
      Kevin Freund
      May 2002
      Northern California
      sorry, maybe this will help you.
      uses existing wiring.
      Aug 2009
      Langley BC, Canada
      Thanks, Thats the one, only I have eliminated my stock regulator and wiring for it.
      I have the alt all wired up except for the wire that goes to terminal #2. It is for the idiot light on the dash except I dont have that either due to a custom dash and I am now using the Autometer volt gauge instead.
      So the real question is do I have to connect terminal #2 to anything or leave it disconnected?
      Kevin Freund
      May 2002
      Northern California
      just leave it open...or make your own warning lamp for it.
      put a warning lamp in your dash- it will tell you right away when the alternator stops charging. you have to use a regular light bulb since an LED won't have enough resistance to trigger the alternator.
      since we're on the topic of dash lights- i always like to have functional temp and oil pressure lights, too.. that way you know right away if it gets hot or you lose oil pressure. plus all those lights look cool when you turn the key on and go off when you start the car.
      Aug 2009
      Langley BC, Canada
      So if I put a lamp in is the alt terminal used as a ground and the lamps other wire to positive or the other way around?
      Kevin Freund
      if the alternator is not setup as a 1 wire, you will need to put the light in to excite the alternator. You must use a standard incandescent bulb. One side of the bulb gets wired to ignition, the other to the alternator
      Fontana, CA
      Quote Originally Posted by all wired View Post
      Yes.
      The two wires in the plug are remote sensing and excitor related. The brown factory wire works. It actually has redundancy built in from the factory in case the light burns out. The wire through the bulb gets resistance from the bulb. there is a parallell resisted wire. these 2 wires meet under the dash prior to entering the underhood as the brown wire. The alternator will not excite if it is not wired here.
      Nick R.
