      Jun 2011
      Central Minnesota
      Rear Stabilizer Mounting Position
      So I was sitting in the shop starring at the car and I had a crazy thought... Does the rear stabilizer bar have to mount "forward"? Typically the rear bar is mounted to the axle and is anchored to the chassis "forward" going toward the LCA chassis mount...
      What would happen to the chassis dynamics if the rear bar was mounted reversed? Mount the bar to the axle and anchor the ends to the chassis pointing toward the rear... More room back there (on my car) compared to mounting it forward.
      Any thoughts?
      Aug 2001
      Connecticut
      same function, I've also seen bars mounted to the rear end where on race cars we typically mounted it to the chassis and just had the arms hooked to the rear end (less unsprung weight by mounting the bar to the chassis)
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Jun 2011
      Central Minnesota
      That's what I was thinking, but... Would change the rear roll center? Or is RC based on the control arms only?
