    Results 1 to 11 of 11
      May 2011
      QA1 and Hotchkis parts don't fit-HELP
      Out in the 110 degree heat ( with a fan) I have a issue. My QA1 front shock #TC1958P will not fit into the shock hole on Hotchkis Lower control A-arm #1104B. The shock is a little to wide. This is for my 64 F-85 build. I double checked on line and these are the correct part numbers. It's Sunday can'Name:  IMG_1009.jpg
Size:  199.6 KBt get anybody on the horn.
      64 F-85 post car Resto-Mod project-my RV when I retire
      Nov 2009
      Country Flag: Argentina
      Well I have the opposite issue, I have GW LCA and Hotchkis (Bilstein) shock.
      I spoke with Hotchkis, and they make the hole for the shocks for the stock size shocks. Global west, makes them so you can have a QA1 shock fit with no issues.
      This is retarded at best if you tell me. I wish our LCA were for the same car because then we could swap them out
      May 2011
      Yes indeed. I bought these off a 66 Chevelle showcar, car never hit the street. I guess I will re-sell them. Should not be a problem I only have $75.00 apiece in them!
      St George Utah
      mount the shock T bar on the inside of the control arm pocket.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Nov 2009
      Wouldn't that raise the suspension by 1"?
      May 2011
      I thought about that, in fact the parts are here in front of me. If I set the shock down in the spring pocket and then set the coil insulator over it the coil insulator does not sit flat on the spring pocket. Thus the spring will not sit flat, Then if we did all this I will not be able to get my spring compressor in there to mount the arm,the shock is in the way. I could try the dangerous way and use my floor jack but this barely a rolling chassis there's not enough weight. That all said then if it all was in there, I cannot get a screw driver in between the coils to adjust the ride tension, the coil insulator is in the way. I called Bilstein their shock will fit. It's a bummer you discover these things after you shell the $$$ and the MFR. has no warning or disclaimer
      Templeton, CA
      I had to open the shock opening on my stock lower control arms when I installed the Varishocks. I called Chassisworks and they told me there had to be a little fabrication involved! I wish I would have found this out before I had them powdercoated. Duh!
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
      Oct 2008
      Santa Fe Springs, CA
      Quote Originally Posted by therobski View Post
      TheRobski,
      Sorry to hear you had a frustrating day in the shop. Unfortunately it’s not always feasible to make every part work with every possible combination of parts available in the aftermarket. Our geometry corrected tubular A-Arms are designed to improve handling and be a bolt-on with either our recommended Hotchkis tuned Bilstein HPS shocks, or other high-performance handling shocks like Koni. The TC1958P is a QA1 drag race shock designed specifically for stock suspension drag race classes, which is probably why you had a fitment problem. If its possible, you’d be better off going to a shock designed for handling if that’s your end goal – you’ll reap huge rewards in vehicle dynamics and control not to mention an easier installation.
      Hotchkis Sport Suspension
      Toll Free: 877-466-7655
      May 2011
      I called QA1 and they said that even with stock GM A-body A-arms the shock hole needed massaging. That's crazy in my book and to discover after the fact that they are not compatible with my new pair of Hotchkis A-arms. After spending the $$$$$ on these I will be calling Mark at Hotchkis and ordering the tuned Bilstein's and sell the QA1's.
      Rustburg, Virginia
      That is a big shock body(compared to the stock original shock)....I would expect to have to open it up a little.
      St George Utah
      Quote Originally Posted by sebtarta View Post
      No it will shorten the shock travel by about 3/4" on compression and add 3/4 to the extention, (which could be a benifet if dragracing was the objective)but has no effect on the ride height as the spring has not changed.
      Blake Foster
      435-628-4300
      St. George Utah.
