    Results 1 to 20 of 25
      Clunking noise when turning
      Hi guys, I've been chasing a clunking noise coming from my right front wheel when turning left. It only occurs on left turns, and the more throttle I give it the worse it gets. I've got a little bit of top to bottom play on that wheel that isn't there on the left side. I've already changed the upper ball joint as it was fast cheap and easy. Any suggestions on where to go from here. Thanks this is on my 67 RS/SS
      May 2011
      Central FL
      Check the A-arms for damaged or missing bushings?
      - David
      1967 Camaro - In remembrance of my friend Scott
      Nov 2007
      Golden, CO
      I had a cross-threaded upper spindle bolt, that big 1" bolt, that allowed a little slop. Didn't find it till disassembly of entire front suspension.
      It's been fine till the last 300 miles or so. I've got 4k without a problem. I did find the rear bolt on the upper a arm had backed out a but so I tightened it down. No change.
      Central Florida
      What control arms are you using? What about shocks? I have a similar problem that I can't track down.... I've replaced upper and lower balljoints (both sides) tie rods, idler arm, checked wheel bearings..... I have GW upper & lower with coil overs. Let us know if you find the cause.
      Thanks - Patrick
      I have stock upper and lowers with poly bushings.
      Have you checked wheel bearings? I've chased clunks to that before.
      ​John Parsons
      Nov 2010
      Possibly jack up the right side and have some one turn the wheel while you try moving the wheel/tire assembly. Maybe you will be able to feel and or hear whats loose...? Is it making the "clunking" noise when you are parked and turn the wheel, or is it only when under a load? I would go through all the suspension, steering and wheel parts and double check everything for proper fit and any incorrect assembled parts. Hope this helps
      Ramona, Ca. San Diego area
      I know this may be a long shot but make sure your wheel weights aren't hitting your steering arm. Just throwing out suggestions.
      67 Camaro convertible (Jinx)
      wheel bearings were defiantly on my list especially where there was play in the wheel that isnt there on the drivers side. What would i be looking for with the bearings other then obvious defects. Ill look at the wheel weights, as it sounds as if something is hitting in one spot as the wheel rotates around. Thanks
      Jan 2011
      Boston, MA
      Does it clunk just once when turning the wheel to the left or does it happen with every revolution of the wheel/tire on left turns?
      mike@schwartzperformance Guest
      We have seen upper spring cushions worn out and when you get metal on metal contact it creates a popping sound, however this would not happen every time you turn left.
      Oct 2006
      Caliper and wheel contact?
      I took apart the dust cap on the spindle and got the castle nut to turn 1 more spot. That took the play out of the wheel, but it's been raining here all week so I haven't been able to drive it to see if it helped. Will post results when u get some.
      Jan 2011
      Boston, MA
      Make sure you don't cinch that castle nut down too tight, you can ruin the bearings very easily that way. I think they only get torqued down to 12 ft-lbs. If you pull the bearings, you should be able to spin the rollers easily and feel no deformity. If not, they are only $5 or so to replace.
      Jun 2011
      Vette City, USA
      Two easy things to look at are stabilizer end links and shock mounts. If the stabilizer bar end link is loose or missing the bottom bushing, it will make a clunking noise when the slack is taken out. I just rebuilt my front end and discovered my 25 year old urethane bushings were crumbling apart and making my clunking noise.
      Second, if the shock mounting rubber bushings are destroyed, they can allow the shock to do basically the same thing as the sway bar. Easy to check, easy to fix and easily overlooked. I did for a year chasing my problem with the sway bar links.
      Old enough to know better, young enough to think I can get away with it.
      Jan 2011
      Boston, MA
      Quote Originally Posted by knucklebusted View Post
      This is why I was wondering if it was clunking just once or with every wheel revolution. I had a clunking sound in my front driver side and it was coming from the stabilizer bar end links. Someone had put the bolt in from the bottom, with the long end pointing up and when you turned the wheel, the bolt would rub on the castelated nut on the top front of the spindle:
      Sep 2007
      Had a similar experience, every time you made a right turn. I first checked wheel bearings, ball joints, tie rods and found nothing. Turned out that the spring was cracked at the very top where it sits in the frame. Almost did not see it, really need to look closely with a drop light. Take a look.
      I finally got around to playing with it and it seems that the extra little on the castle nut has taken care of it. im going to keep a close eye on it though. thanks for all the suggestions.
      I lied, clunking came back today. gonna keep digging.
