      Nov 2010
      Procharger for a carbed bb chevy
      Who sells a blow through setup for a bb chevy with a carb. Its going in a 64 impala. Any ideas or opinions as to what would work best would be great. I know procharger has a universal set up but who has delt with the install and is it worth thr money. I will be running low boost since im running the stock bottom end.
      Mar 2010
      Alabama
      If you are going carb'ed you have better either go with CSU or C&S for the carb. Go ahead and spend the money on the front end and save alot less headache trust me I know from experience lol. The best is Brent Davis over on turbo forums. His setup the "crutch" is the best setup. How much hp you loking to make and I am assuming 95% street car?
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Nov 2010
      Quote Originally Posted by DButler View Post
      Yes...its going to see daily street use. I'm lookin to make around 550 to the wheels. I've thought about just doin AFR heads and a roller cam, but i like the idea of boost with a basic 454. I'm not lookin to make peak power, i just want a fun boosted bb if ya know what i mean. I'd like to keep the stock heads, buy a carb and cam for boost, and run it. Any help and advise would be great! Thanks for the reply
      Mar 2010
      Alabama
      Its a little more to it than cam and carb lol but not that much. I would recommend probably CSU for the carb they can match it to your setup. The main thing is going to be your fuel system. I would go Aeromotive with their A1000 filters and boost referneced regulator. You will need someway to control your timing as in an MSD pro billet locked out with a 6AL BTM or digital box to pull timing. This should be the basic. I would go over to tubroforums and searcha dn read like crazy before doing anything (wish I would have). There is more than enough info over there to give you an idea of what you will need and so on.
      David Butler
      Nov 2010
      Quote Originally Posted by dbutler View Post
      its a little more to it than cam and carb lol but not that much. I would recommend probably csu for the carb they can match it to your setup. The main thing is going to be your fuel system. I would go aeromotive with their a1000 filters and boost referneced regulator. You will need someway to control your timing as in an msd pro billet locked out with a 6al btm or digital box to pull timing. This should be the basic. I would go over to tubroforums and searcha dn read like crazy before doing anything (wish i would have). There is more than enough info over there to give you an idea of what you will need and so on.
      thanks for the input!
      Aug 2006
      austin
      I'd avoid the locked out timing. I tried it on my poncho and didn't like it. Car was sluggish at part throttle with only 20-25 degrees advance.. Fortunately, my 8:1 compression made it easy on the starter. I eventually went full NA timing curve (38 degrees) and pull 1.5 degrees/psi with BTM.
      I'm using a Demon blow through. I def think you could do better, but I got a great deal on it
      Def do the Aeromotive complete system.
      Greg
      1976 Trans Am SacrilEdge
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      https://www.pro-touring.com/showthre...ect&highlight=
      https://www.pro-touring.com/showthre...ilEdge-is-free!
      Mar 2010
      Alabama
      I run my timing locked at 34 degrees base and pull 1 degree per pound of boost. Plus I am running a phased rotor that way when timing is pulled it is still hitting on number one at the lowest timing and highest boost level.
      David Butler
      UK London
      Quote Originally Posted by opnwide View Post
      I too am running N/A style timing with vacuum advance and pulling degrees with MSD 7531. I also have 7.8:1 CR even though the MSD has 10 degs start retard. I've found with low boost, low compression and high cfm the car seems very responsive and torquey. I can't help wondering what is would nave been like at 9.5:1!!!
