Thread: touring 70 monte, convert to FI
06-09-2011 #1
- May 2008
- portland, OR
- 7
I have gotten some great help here before so I thought i would ask here about the fuel injection.
A little overwhelmed with the right choice for the injection system. not sure which intake injector size or ecm to run.
I want to make sure I have the right air volume, enough fuel with good reliability.
I need it to be very reliable as a top priority.
This car is a daily driver touring car 1970 monte. I worked with mark at sc&c and did the whole suspension front and rear. The car handles great now would be very smooth if not for the 20 inch rims.
engine and exhaust just got done
Did the 3 inch oval from ram air restoration into the long spintechs and 3 inch over the axle. kinda loud but sounds great.
engine 1969 427 bored .60 with nitride sleeves
heads rectangular port
11:1 compression
forged and balanced internals
comp cams 290 degree hydraulic tappet
I'm not really a fan of the carburetor style intake as far as the look but maybe its the best choice i'm not sure.
I would like to be able to control everything to take full advantage of EFI i.e. timing by using a dual sync distributor. Just tune it once and have some versatility if i decide to add some air to it later on.
thx
06-09-2011 #2I would suggest looking at the Delco ECMs that come in the '80s to mid '90s GMs.
They are very reliable, have limp home mode (if the proper MEMCAL is selected as a close match), on board diagnositics, will control fuel and spark, come in a variety of flavours, TBI, MPFI, N/A, forced induction, etc. They can be used with a dizzy or with DIS as well.
Check out http://www.eagle-mark.com/Forums/ for information along with wiring diagrams, and many other files for a variety of applications.
I use Delco ECMs in my conversions, easy to tune, inexpensive, and just plain work.
I have a Delco ECM running the Nissan engine in my 1973 Datsun 240Z.
06-10-2011 #3
