    Results 1 to 20 of 22
      Nov 2009
      New York
      Fast EFI question
      Ok I finally placed my order for the Fast EFI kit, purchased the one with the fuel pump.
      Now for the question. I also purchased a new fuel tank, pickup and straps. I know this system needs a return so I was going to weld on a bung so I can use AN fittings. Is it best to have the connection at the top of the tank? Also, I was going to weld a bracket to the back of the tank to hold the fuel pump, good Idea or bad?
      Anything else I should know about installing this kit (PN 30227)?
      Thanks for the help
      John
      Feb 2011
      Where the hosers are.
      When I do a return line, I like to have it return high in the tank and then have a tube on the inside that runs straight down and has between 1/2" and 1" of clearance to the bottom of the tank. I will also place the return as far away from the pick up as possible to avoid aerating the fuel being picked up to go to the pump.
      1973 Datsun 240 Z
      2.8L Turbocharged and Injected, WIP.
      DIY Fuel injection forums and information
      Nov 2009
      New York
      Quote Originally Posted by Six_Shooter View Post
      Great tip about placing it far away Thanks
      Nov 2009
      New York
      Fuel Tank Question
      Hey Guys never installed an EFI system, What do you think about this idea of mounting the pump. Also, I welded in a threaded bung for the return line. Before I paint the tank I would like to know if this is a good or bad idea? Also, the Fast EFI needs a 3/8 return line, so I was going to use the factory steel line from the old system and run the new line from the pump to the EFI system, this ok?Name:  DSC_0019.JPG
Size:  159.5 KBName:  DSC_0017.JPG
Size:  92.5 KBName:  DSC_0018.JPG
      Thanks for the help,
      John
      Feb 2010
      Hate to be the bearer of bad news, but you mounted the pump right where the passenger side strap wraps around the underside of the tank. You won't be able to bolt it to the car.
      Nick
      '72 Monte Carlo
      Build Thread
      Nov 2009
      New York
      Thanks Nick I thought of that and tested it. I made it stand off the tank so the strap fits behind the pump and does not hit at all
      John
      Feb 2010
      Glad you thought of that. I always seem to find those things out the hard way. Let us know how the EZ EFI does. I've been tempted to give it shot; it looks like a real nice system.
      Nick
      '72 Monte Carlo
      Build Thread
      state college, pa
      I think you will like EZ Efi, but you have the pump set up backwards.
      Nov 2009
      New York
      Quote Originally Posted by d69bird View Post
      lol nice catch I see it now, Glad I didn't use the wrench on it yet I will spin it around. Also I see now looking at it, I could drop the pump further down by flipping the brackets.
      Nov 2009
      New York
      One other question, what about venting? Is it ok to just replace the gas cap with a vented version?
      Nov 2009
      New York
      Painted and pressure tested time tomorrow she goes in the car
      Thanks for the help.
      John
      Nice job it looks good.
      Jul 2007
      Los Angeles, CA
      Nice, that will just disappear under the car.
      Nov 2009
      New York
      Guys I am blown away how nice it works It is like driving a new car. Tomorrow I will put the MSD box in.
      Glad to hear you like it and its working good for you..
      Lawrenceburg, TN
      Jun 2010
      Western Kentucky
      How do you like the system?
      Have you had any trouble with fuel starvation, by using the stock tank?
      Nov 2009
      New York
      I like it. really works great. No problem at all with the tank even below a 1/4 tank. I had more problem with the timing then anything.
      John
      Rustburg, Virginia
      Did you get the FAST XFI system?...I'm looking at the TPI-FAST XFI and just can't pull the trigger yet. Still reading up on it plus have another project eating up my funds at the moment.
      Nov 2009
      New York
      No I went with the standard EFI I heard the XFI is better but too late.
