    Results 1 to 13 of 13
      Jun 2009
      norcal
      Lightweight Flywheel
      Hey guys my head is spinning! I have a 68 firebird with a Pontiac 350, and will be installing a t56 out of a 02 ss with a 1st gear 2.66 and my rear is 4.10. So my question is lightweight aluminum 15lb or steel 30 lb? or is ther something in between.
      Oct 2005
      Corona, CA
      For street cars, I always run a SFI rated steel flywheel.
      Nor Cal
      Depends on your intended usage, but I've daily driven an alum LWFW and loved it. And that's in a hilly city.
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Jan 2007
      CT
      My experience with the 30lb flywheel and the t56+4.10 combo was it is notably slower reving. I have a 18lb flywheel now and love it. it is very streetable even with my higher RPM engine.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      Dec 2002
      Lost Wages, Nevada
      I'm a fan of light weight alloy myself...
      Apr 2011
      Ewing, NJ
      I have had an aluminum flywheel in my Camaro for years and even with a very aggressive clutch it is great to drive. Just get one from a name brand, not some cheap eBay stuff. Any reputable brand will be SFI rated.
      -Tim
      NJSPEEDER - Tim Mullaney
      New Jersey F-body Owners Association
      www.NJFBOA.org
      NJ's home for all owners, friends, and fans of Camaros and Firebirds
      Jun 2009
      norcal
      Thanks for your reply guys. Any recomendation as to weight. 15/18/25? and typically I understand Pontiac mototrs dont do well with the high revs, is that a myth>
      Henderson,NV
      I want to swap my steel for aluminum. Mainly for rpm matching and quicker revs. Of course I have a big block with 641 ftlbs and can take off in 2nd without much trouble.
      Todd
      Dec 2002
      Lost Wages, Nevada
      Around 15 is typical for SBC applications and a single disk.
      Apr 2011
      Ewing, NJ
      Quote Originally Posted by rechin23 View Post
      Do you know who you are going to be buying your clutch from? They should be able to tell you or more than likely sell you the right piece.
      -Tim
      www.NJFBOA.org
      Jun 2009
      norcal
      I havent decided on the clutch yet, I figured I would ask here first about the flywheel.
      Dec 2007
      Carlsbad, Ca
      my mcleod billet steel is 24lbs, and thats .200 thicker than their normal ls flywheel. not sure what a pontiac fw would weigh from them. the aluminum one that i returned was 14-16lbs and it was .200 thicker as well. i will be running 3.73s, 2.66, 3900ish lbs and a 28.5 tall tire. i could go back to the aluminum, but im not sure it will be enough.
      Tim
      Build Thread Link
      Henderson,NV
      Tim, I think you are making a good choice. Heavy, tall first, and tall rear tire.
      Todd
