    Results 21 to 25 of 25
      Need a good solder gun and a source for the various connectors for a 68 Camaro.
      I have an 18 Circuit Painless kit, and it will work well for me the little I've messed with it.
      However, I will need a few connectors as some were lost over the last decade. I'd like to just buy a set if I can, rather than in ones and twos. I'm not sure what I have, though it will be a bit before I need them. I have the big stuff like the headlight and ignition switch but may need the smaller light connectors other than the headlights.
      Also, I need a better solder gun I think. I'm making a wire harness for my gauges and the solder iron I have just doesn't seem to transfer heat very well. I may use a gauge wiring harness if it will work. 2 5" Autometer and 4 of the smaller gauges.
      Using the Power Up Kit from M.A.D. and the Klien Crimpers and I'll be using circuit breakers rather than fusible links if anyone has some advice on that. battery in the trunk, remote solenoid.
      Thomas
      Spare Change: 68 Camaro, 300hp/350ci, 700R4
