    Results 41 to 60 of 66
    1. #41
      Jul 2008
      Dallas, TX
      Are the axle splines modified for the 1* camber? I know a lot of circle track guys do that, but I always wondered if it was just a matter of modifying the housing and that's it, or if there are more mods required.
      '69 Chevelle - LQ4/T56
      '71 GMC SWB Fleetside - LM7/AR5
    2. #42
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by claytonisbob View Post
      Yes, the axle splines where they fit into the drive plate are crowned. Will try to get some pics posted.
      Scott
      Check out my YouTube channel for vintage car and truck rescues and rebuilds! THE BULLETPROOF GARAGE!!! - YouTube
    3. #43
      Jul 2008
      loudon,tn
      cool project. nice to see something different on here! i am starting an AMC project myself,but i am not throwing it out there yet. have you decided on the front suspension yet? i am up in the air about mine.
      drive it like you stole it!
      1971 duster "deb"
      2016 GMC duramax tow rig
      1975 AMC matador coupe-long term project
    4. #44
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by 71duster View Post
      Plan is to go with the complete Freakride IFS. Only concern is the budget - - this will set me back $3,700 or so.
      Scott
    5. #45
      Nov 2011
      Pensacola, Florida
      Bulletpruf, currently running the Control Freaks IFS front suspension and the triangulated 4 link rear. The suspension is just amazing on the Hornet! My car was a test mule for the Spirit, Hornet platforms. Just cant describe in words the ride and performance difference there is! Plus big weight savings over the stock suspension parts. Will keep following along with your build on your AMC project.
    6. #46
      Jun 2011
      St. George, Utah
      Great project of a different car. Looking forward to more!
      SRD on Facebook
      79 Cutlass wagon build
    7. #47
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by Hornet LSX View Post
      I spoke with Al Kamhi at a recent AMC show in Atlanta and saw one of his demo setups. It's not cheap, but seems to be the right way to go for me.
      Nice Hornet (even if it does have a shivverlay motor in it!).
      Scott
    8. #48
      Ontario, Canada
      Nice Hornet. Any idea how much weight savings for front? Rear? Thanks.
      Duane
      '74 AMC Javelin AMX
    9. #49
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by AMC Racer View Post
      Control Freak setup saves you about 60# in the front.
      Scott
    10. #50
      Jan 2009
      San Antonio, Texas
      Picked up a set of used Toyo R888's at Road Atlanta this weekend in the size that I need - 275/40/17. They have a little life left in them, but were bought mainly to use as rollers, check fit, backspace, etc.
      Also picked up some nice boxed lower control arms at Road Atlanta from Jeff Puras - he's a retired jet mechanic and does very nice work! Picked up a clean pair of upper control arms from Jeff as well; one of mine has had some welding done to it. Plan at this point is to at least start off with stock front suspension coupled with coil-overs and aftermarket brakes. Here are the boxed lowers -
      Got one of the hubs and calipers on. Other side is fighting me.
      Scott
    11. #51
      san diego
      Jan 2009
      San Antonio, Texas
      Continue to make steady progress...
      Started stripping the paint out of the engine compartment.
      Rear shocks have arrived, so rear suspension is almost done. Just have to finish up by finding better hardware to secure the leaf springs. Would like to find better leaf spring shackles as well; stock stuff looks a bit thin.
      Think I have the hub issue worked out - - the seal on the back of the hub and the bearings were hanging up on burrs on the threaded portion of the axle tube - - chewed up the seals on both hubs. Sanded the burr down and now things are sliding on and off nicely.
      One of the axles was too long; Speedway recommends that the end of the axle sit about 1/16" - 1/8" below the level of the drive plate. Driver's side was right at 1/8" below drive plate - good to go. However, the passenger side was .73" below the drive plate. The axles are threaded on the ends so you can screw a bolt in the end (jam nut it w/plenty of red Loctite) to space the axle out a bit, but this would have spaced the axle out too far of the splines in the TrueTrac diff, which only has 1" of splines, and the splines end 1 1/8" outboard of the spacer in the diff. Have a 32.25" axle on the way; it should be dead on or maybe 1/16" too long. If so, I can take a bit off the end to dial it in just right.
      Working a deal on brakes - Wilwood 6 piston SL-6 calipers with 12.8" x 1.25" rotors (2 piece w/hats drilled to 5 on 4.5"). Brakes are used, but not all beat up and come with a few sets of Hawk DTC 70 pads (pads are worth about what I'm paying for the entire setup). Also have some drum spindles and hubs on the way. Plan is to rebuild the calipers, use the drum hubs, fab up mounting brackets.
      Scott
    13. #53
      san diego
      Scott have you looked into the EBC blue stuff. They actually tell you the coefficient of friction vs temperature. About 120 bucks.
    14. #54
      Jan 2009
      San Antonio, Texas
      Quote Originally Posted by Bryce View Post
      Just checked out their website.
      Scott
    15. #55
      Jan 2009
      San Antonio, Texas
      Ok, project has been somewhat stalled while I worked on other cars (latest project is a 68 GTO convt, hideaways, strong 455, TH400, 3.90 gear).
      Anyway, I'm back on it. Engine is about ready to start on the test stand. Will be closing off some extra holes in the firewall this weekend. Then I can prep and paint the engine compartment (battleship gray) and get started on engine/trans installation and front suspension assembly.
      Front suspension will be mainly stock, but with boxed LCAs and coilover shocks - using the kit from WSC Motorsports. Will have to fab a mounting bracket for my Wilwood brakes, too.
      Scott
    16. #56
      Jan 2009
      San Antonio, Texas
      Ok, the firewall is starting to look better.
      You can pretty much follow the progression of the photos below, but I stripped the paint from the engine compartment a while back. Took it down to the metal.
      Then treated with a metal treatment - Picklex 20, I think - kept it from rusting.
      Then made some templates for the necessary patches using a sliced up manila folder.
      Traced out the templates on a sheet of 18 gauge sheetmetal. Cut them out with a sheetmetal nibbler and then shaped with die grinder, cutoff wheel, hand file, etc. Took quite a while before I had them all fitting just right.
      Then I prepped the areas to be welded - ground down to the metal with a angle grinder. After it was down to the metal, I sprayed it with Eastwood's weld through primer.
      Since welding thin stuff gives me fits, I called in some experts - local AMC'ers Jeff Reeves and Jeff Puras came over to lend a hand. Jeff Reeves laid down some nice beads and affixed the sheetmetal patches to the firewall. Most were lap welds; only one butt weld. Anyway, big thanks to the 2 Jeffs for their help; it came out great.
      I then ground down the welds with an angle grinder and painted with more Eastwood primer. Next step is to strip and prep the entire engine compartment for primer and paint.
      Scott
    17. #57
      Aug 2006
      Vinland Kansas,66006
      Lookin good.My 16 year old son & I are working on a 71 javelin for him.He has a build thread over on Laterl-g.net.Brandon will watching your build for Idea's.
    18. #58
      Cartersville, GA
      71 Javelin Road Racer Build
      Nice! I just picked up a '71 Gremlin for my son, and we're seriously considering the Control Freak front, and fabbing our own 3-link for the rear.
      Joe Hinds
    19. #59
      Jan 2009
      San Antonio, Texas
      Fellas -
      Build is stalled. Moved to Korea in 2013 (active duty Army) for a 2 year tour. Headed to Italy this summer - going to Naples. Think I'm going to take the Javelin with me, but will probably need some help to finish it.
      Think I can do all the rest of the work; have tools and fair amount of know-how, but will need someone to oversee and advise.
      Does anyone know of someone who consults on projects? I don't mind paying a fair price; just need someone available via e mail and possibly periodic phone calls.
      Please post here or PM if you know of anyone who would/could handle this.
      Thanks!
      Scott
    20. #60
      Nor Cal
      Quote Originally Posted by Bulletpruf View Post
      Fellas -
      Thanks!
      Scott
      Scott, here is your man!
      http://www.lateral-g.net/forums/showthread.php4?t=42423
      http://www.ronsutton-racetechnology.com/
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
