    Page 2 of 2 FirstFirst 1 2
    Results 21 to 26 of 26
    1. #21
      Feb 2011
      Chico, CA
      Yes, take the hood off, mark your holes before you do so though to keep the alignment where you have it. Some guys will do this by drilling a 1/8" hole in each side of the bracket/hood. When you go to put it back on, put a rivet in there and bolt it up!
      Too bad you aren't closer, I have two engine stands that I am storing until I get another motor on there, I'd let ya borrow one!
      Jeff
    2. #22
      Jun 2009
      Central FL
      The stand ended up being for a friggin big block, so it's sort of in the stand and still held by the cherry picker.
      Got it out with one chain diagonal across the driver and passenger side heads. Came out smooth.
      Thanks guys.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
    3. #23
      Aug 2008
      Pgh, PA
      Quote Originally Posted by Vicinity View Post
      Thanks guys.
      Strange. Most engine stands are kind of "universal" and can be adjusted.
      '66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
    4. #24
      Jun 2009
      Central FL
      Quote Originally Posted by wmhjr View Post
      Well, this one isn't what I'd call a "stand". It's a cube of square steel welded together with stops on both sides of where the engine sits. The engine can roll around between the stops, I put some soft wood on both sides to stop it from rolling. It really doesn't "seem" safe.
      Dan
      1968 Camaro v2
    5. #25
      Aug 2008
      Pgh, PA
      What you've got sounds like an engine "cradle" and not an "engine stand".
      Here's a cradle: http://www.jegs.com/i/JEGS/555/80065/10002/-1
      Here's a stand: http://www.jegs.com/i/JEGS+Performan...80040/10002/-1
    6. #26
      Jun 2009
      Central FL
      Yeah, that sort of looks like it. This one is homemade, though. =\
      Does Autozone rent them, I wonder?
      Dan
      1968 Camaro v2
