Results 21 to 26 of 26
Thread: Engine Hoist Mount
05-11-2011 #21
- Feb 2011
- Chico, CA
- 203
Yes, take the hood off, mark your holes before you do so though to keep the alignment where you have it. Some guys will do this by drilling a 1/8" hole in each side of the bracket/hood. When you go to put it back on, put a rivet in there and bolt it up!
Too bad you aren't closer, I have two engine stands that I am storing until I get another motor on there, I'd let ya borrow one!
Jeff
05-11-2011 #22The stand ended up being for a friggin big block, so it's sort of in the stand and still held by the cherry picker.
Got it out with one chain diagonal across the driver and passenger side heads. Came out smooth.
Thanks guys.Dan
05-12-2011 #23
05-12-2011 #24Well, this one isn't what I'd call a "stand". It's a cube of square steel welded together with stops on both sides of where the engine sits. The engine can roll around between the stops, I put some soft wood on both sides to stop it from rolling. It really doesn't "seem" safe.
Dan
05-12-2011 #25What you've got sounds like an engine "cradle" and not an "engine stand".
Here's a cradle: http://www.jegs.com/i/JEGS/555/80065/10002/-1
Here's a stand: http://www.jegs.com/i/JEGS+Performan...80040/10002/-1
05-12-2011 #26Dan
