      Enfield, CT
      Compushift TPS calibration problem
      Hi, I have an original Compushift, plugged into a 4L60E. The engine is an LS3. I'm having problems calibrating the TPS. According to the directions, we connected the grn/wht wire to to the low or grounded side of the TPS (pin "C" - Low Reference) and the solid green wire to the sensor signal. Problem is there's two sensor signal wires at the TPS. First we connected to TPS Sensor Signal 1 (pin "D") and we got a code 17 from the Compushift, and it didn't want to upshift. We then switch the wire to TPS Sensor Signal 2 (pin "F"), and now we get a code 16 and it wants to downshift to early. We've gone through the calibration procedure several times.
      Any ideas?
      -Colin
      '67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
      https://www.pro-touring.com/showthre...7-GTO-LS3-Swap
      Dec 2009
      Hey Colin - I have a good friend who's an engineer over there; former satalite engineer. Send me a PM if you'd like his contact info...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
