    Results 1 to 10 of 10
      Nov 2010
      Minneapolis, MN
      After market Gauge Question
      I am in the process of putting an L92/6L90e into my 67 Camaro, and am currently looking for new gauges. I am trying to decide between the Dakota Digital VHX system, and the New Vintage USA 1968 3-1 gauge set. (I like the fact that both systems only use the two stock gauge sockets--I do not have a center console)
      Does anyone have experience with either/both? I like the aesthetics of both systems, but am not sure which one would be easier to implement. Dakota Dig is about $795, while the New Vintage is $599 + a $50 dollar bracket. I have done some research, and believe the Dakota set up is a cleaner install, but it is more expensive.......
      Any thoughts? How does the New Vintage set up look in person?
      New Vintage:
      http://www.newvintageusa.com/future.html
      http://stores.newvintageusa-store.com/-strse-104/1968-SERIES-3-dsh-1-GAUGE/Detail.bok
      Dakota:
      http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=721/category_id=636/home_id=-1/mode=prod/prd721.htm
      Bobby
      -67 Camaro in process: Speedtech Track Time Pkg (AFX Spindles, C5 Zo6 brakes, rack, rear torque arm, 9", Ride Tech coils, and a L92/6L80e Swap).
      -2005 Jeep Rubicon Limited LJ, 35"er's, 6" Nth Degree Lift, Hanson Bumpers, 8274 Winch, with a Redbone Coonhound in the backseat.
      May 2009
      Minnesota
      Can't help much, but I have been looking at the New Vintage 3-1 gauges and they have a very nice clean look to them. The DD seem a little to modern looking for my 68 Firebird. I was hoping that the New Vintage gauges would have been a little closer priced to the original quote when they were being introduced. Just my .02
      I had Mark at New Vintage USA make a custom set of the 3 in 1 gauges for my 68 firebird. The gauges are top notch! They are even better looking in person. The wiring is not difficult.
      Nov 2010
      Minneapolis, MN
      You're right, I just got mine yesterday! Thanks for the advice!
      Bobby
      May 2009
      Minnesota
      Mine were delivered last week. Very nice gauges.
      Nov 2010
      Minneapolis, MN
      Nice! They look great!
      Bobby
      Jun 2011
      Brooklyn, NY
      New Vintage 1969 is what I ordered for my car as well
      Nov 2010
      Minneapolis, MN
      Tough to beat, I started wiring mine yesterday.
      Bobby
      Jul 2010
      the motor city
      Here are the 68 series installed:
      I went with the DD VHX and got a killer deal from Frank at Prodigy once again.
      They are cool. and pretty easy to install. I like the zero to 60 and 1/4 time function. it's nice to be able to scroll thru and see a digital read out off all the gauges, fuel level in %, volts, mph, tach, water temp, oil pressure,etc.
      There are 2 tripometers, a "service-meter"? set it for different amount of miles and it counts down then flags service engine, hour meter.
      A lot of stuff. not something you're going to check out every time your behind the wheel but...if you need to...like when I was on Power Tour and worried the noise coming from my alternator was a bad thing, I watched the LCD screen that I had showing my volts. 13.2 volts is easier to read then trying to "guess" where the needle is pointing...exactly.
