    Results 1 to 13 of 13
    Thread: varisprings
      Mar 2010
      brighton tn
      varisprings
      Whats the best "backyard" way to get these *&$#% springs compressed enough to get the top flat piece on???They are single adjustable that came with my G-Link. I have tried all kinds of dangerous ways and finally thought somebody has got to know a better way....Thanks
      san diego
      Is the bottom nut on the coilover screwed all the way down? If so you should not have to compress the spring to put it on a coilover. The spring may be too long.
      Mar 2010
      brighton tn
      The bottom nut is down as far as it can go without hitting the knob. The instructions say that I might have to compress it a little but I didn't think it would be this hard! LOL
      san diego
      Do you have spring compressors?
      san diego
      How much do you have to compress the spring? and what spring rate?
      Mar 2010
      brighton tn
      I only need about an inch. I have some coil compressors but they are the ones that go inside the coil. I can nearly get it just by pushing it down but then my hands are in the way!
      Jun 2008
      Try using some ratchet straps. If you only have about an inch they shoul work pretty easily.
      69Mercury cougar XR7 slowly but surely on it's way
      Mar 2010
      brighton tn
      LOL yeah I have tried that but my ratchetstraps were of, let's call it, inferior quality!! I got 'em pretty tight and it looked like it was gonna work. They got really tight and all I could think of was the great deal I got on them. Like 6 straps for $15 or something like that.... Needless to say, the tighter they got, the tighter my ••••••• got too!! I'm gonna get some good straps and try again! Thanks for the suggestion anyway!
      Mar 2011
      Sacramento CA
      It is a good idea to make sure you have the correct spring for the shock first. The g-link uses a 5.15 travel shock with a 12” spring. We have a spring compressor designed for the VariShocks. It is a very simple easy to use tool. http://www.totalcontrolproducts.com/...VAS_200_AT.jpg
      Jim @ Chassisworks
      Oct 2010
      SO.CAL
      Quote Originally Posted by ROLLDAMTIDE View Post
      LOL too funny on those straps..must of got them at harbor freight...
      I would just get some outer coil compressors..
      good luck buddy.
      Mar 2010
      brighton tn
      I GOT IT!! I had two of my heavier co-workers stick the rubberized handles of a 30" pair of channel-locks thru the springs and get on each side to push down against the floor and we got it!! Thanks for chiming in Jim, and nothing against your tool, but I just couldn't make myself buy that compressor!! After getting it seated, the spring is back to almost no load on it so I think it's the correct spring, I just didn't expect to have to compress it to get it on. Thanks everybody. It's been an experience! Hardest part of the G-Link install! ( due entirely to my hardheadedness ) that's a compliment to the G-Link. I have not driven my car yet but the install as a whole, was as simple as I could have hoped for.
      Dec 2007
      Carlsbad, Ca
      i didnt have to compress mine, but my shock is slightly longer as well.
      Tim
      Build Thread Link
      Mar 2011
      Sacramento CA
      Glad you got the springs on !!
      Jim@ Chassisworks
