    Page 6 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
    Results 101 to 120 of 161
    1. #101
      niiiiice!!!!
      Charlotte
      Have you test fitting the headers in the car yet?
      Looked back a few pages and didn't see them mounted.
      You basically building one of my dream projects I've had rolling around in my head the last few years...
      2014 Chevy SS LS3 / 4 Door
    3. #103
      Cartersville, GA
      In the pics, the trans wasn't bolted up, so we wanted to to do that first, then fit the headers. The engine was just sitting on the mounts (bolts in, with a couple nuts on to keep it relatively steady). I'm sure it will have to be lifted off the mounts some, esp on the drivers side. On these engines, the torque convertor bolts are accessed through a hole in the bellhousing (for the starter), so I was reluctant to install the headers ahead of time. I imagine clearance will be tight with the 1 7/8 tubes.
      Joe Hinds
    4. #104
      May 2011
      Atlanta, GA
      Trans is being mounted as I type this and the gas tank with a new fuel pump is going up as we speak too! More pictures coming later today!
      Chris J
      Bulldawg Musclecars
      Sales and Marketing
      2000 Corvette FRC 1 of 115
      441hp/415tq :D
      GA Corvettes Classic Glass Corvette Club
    5. #105
      Cartersville, GA
      I'm about to lock up the shop tonight, after a long day! I got here at 7am, and we just finished up. Thanks to Chris (C5Golfguy) and Clark for sticking it out today, in the near 100 degree heat and high humidity, to really make some progress.
      The GMPP harness is set up for an older style oil pressure sending unit (the small plug one at the top), and the LS376/480 comes with the larger, late Corvette style. We switched this out rather than alter the harness.
      The transmission cooler line fittings that were supposed to fit...and didn't. We wound up buying a pair of 9/16-18 to AN6 steel adapter fittings from a local hydraulic supply for $2 each (rather than the $27.30 Summit gets for the ones that don't fit).
      The Vette filter/regulator assembly with all the AN-6 Russell quick disconnect fittings. Hadn't mounted it yet.
      The tank, back in all clean and painted, with the modified GN sending unit/pump assembly inside. Something I forgot to photograph beforehand! Its set up with AN fittings for the feed, return, and vent, all plumbed in -6 AN.
      The assembled rear brakes:
      Looks like Anacondas are swarming the LS3! The headers fit well, but took some finagling to get in.
      Goodnight folks!
      Joe Hinds
    6. #106
      good work Joe!!!
      Cartersville, GA
      Thanks Kev! Today should be far less strenuous, though there is still a lot left to do. Mostly finishing up plumbing and electrical, mounting the radiator, etc. The shop is air conditioned, but we hadn't really needed it til now and discovered it needed a charge. Hopefully that will be fixed today, since we're looking at high 90s again. Even on its hardest, longest days, this still beats my former career (stockbroker and financial advisor)!
      Joe Hinds
    8. #108
      Apr 2011
      CLARKSBURG,WV
      Hello members of Pro-Touring. My name is Tom Gerrard and Project Grocery Getter-1983 Malibu Wagon is my car. I have been reluctant to post anything up till now as I am not affluent to the cyber world. Now down to the true reason for this post. Joe Hinds and his staff at Bulldawg Muscle Cars was a great decision for me. Theses people give you and your car 120%. They are Thoughtful, Courteous and Professional. If you do not have the mechanical or physical ability to build your own car you cannot go wrong with these people. I shipped my car 600 miles to get it there and if I had it to do over I would ship it from anywhere. Thank you for your time and THANK YOU JOE HINDS AND BULLDAWG MUSCLE CARS.
    9. #109
      Cartersville, GA
      Wow, thanks Tom! I had my whole crew come in and read that, and we all greatly appreciate the kind words.
      Here is the sending unit for the oil pressure gauge, and the AutoMeter adapter fitting to make it work
      The KRC power steering reservoir...all their stuff is very nice!
      An engine shot with the radiator hoses mocked up. Note the Gates Power Grip clamps.
      The last one has the new Spectre cold air intake installed. Its for a new Camaro. It came with a shield to block off the underhood air, but it will need some trimming to fit the Malibu's engine compartment.
      The power steering hoses are being made, and will be ready in the AM. We're getting very close to wrapping this one up, and should be doing the test drive later tomorrow.
      Joe Hinds
    10. #110
      looks great Joe good work! congrats Tom very nice ride and welcome to the forums!
      Rustburg, Virginia
      Love the KRC stuff...like you said, it's all very good
    12. #112
      Cartersville, GA
      Quote Originally Posted by John Wright View Post
      We are fortunate that they are only a few miles away from us, in Kennesaw GA. Mike and Norm at KRC have been a big help to us, on this project and others. They are currently working on a very compact accessory drive for LS engines that will soon be the industry standard.
      Joe Hinds
    13. #113
      May 2011
      Atlanta, GA
      Mr. Gerrard,
      Thank you for your kind words. I'm starting on Monday full time working with Joe and the rest of the crew. It's safe to say, that we are all looking forward to meeting you and having a chance to spend some time with you. See you soon!
      Chris J.
      Quote Originally Posted by tom gerrard View Post
      Chris J
      Bulldawg Musclecars
      Sales and Marketing
      441hp/415tq :D
    14. #114
      Cartersville, GA
      The whole crew is working hard to get Project Grocery Getter finished up today. We're finalizing the tailpipes and extensions (side exit, under the 1/4 panels), running trans cooler lines, hooking up the transmission linkage, and soon we'll be firing it up. Sorry for no pics since yesterday...LOTS has been done, but no time to upload them. Hopefully later today!
      Joe Hinds
    15. #115
      May 2011
      La Porte, tx
      Cool we are waiting this is a killer car makes me miss my 79 wagon
    16. #116
      Cartersville, GA
      We ran into a few minor issues...the exhaust taking longer than expected, and chasing down a few gremlins, but its VERY close. Pics by tonight!
      Joe Hinds
    17. #117
      Cartersville, GA
      Grocery Getter LIVES!!!
      Joe Hinds
    19. #119
      Cartersville, GA
      Clark getting into his work...literally!
      The radiator is Afco, with a fan assembly from Entropy Radiator, modified to fit (it was intended for a Mustang) and held down with brackets we fabbed
      We had an issue with the fuel pump connector not making proper contact, but some quick testing found the problem and got it resolved. Jeremy is on the left, Clark on the right
      The Corvette covers took some minor cutting to fit around the Quik Performance air conditioning bracket and lines. The rear was also cut to clear the heater box, and one of the lower supports removed.
      Joe Hinds
    20. #120
      good job guys!!!! looks great!!
