    Results 21 to 29 of 29
      Nov 2010
      southern wva
      another ls pan question
      i pulled the trigger on a ls-2 for my 68 f body it has what i was told a corvette pan (no wing's) any way this is the question, i have seen where some folks have modified some of the stock pans to fit the first gen's and other's. so what would be the problem with the lh-8 pan (hummer pan) if you where to cut the sump to make it shorter? ok i get the obvious less oil but would it be enough to hurt it? or maybe i should notch the one that came with the motor. one more question a found a post that i thought was here where some one had posted all the ls pans to compare them but cant seem to find it agian?
