Results 21 to 38 of 38
Thread: Varishock installation
I started installing the Varishocks I just got. Quickset2 for front and rear. Going on the Pontiac, which as OEM style spindles, and the SC&C stuff (tall ball joints, adjustable UCA, tubular LCA, SPC springs, Hellwig tubular sway bar).
To be honest, it's been a PITA so far. Since the shocks are too large to fit through the opening in the tubular lowers (or stock ones, for that matter) the LCA needs to be separated from the spindle to allow the shock to be installed inside first. So you have to bolt the ears of the shock bottom to the LCA, then slide the coil spring over, then (here's the combination) rotate the LCA up, align the ball joint with the spindle, keep the coil indexed properly, and get the top of the shock shaft through the upper mount. Whew! After a bunch of head scratching and multiple attempts I did get one on. BTW, I did know in advance that I'd have to do this, but didn't expect it to be quite as much of a pain.
Here's the question for any of you Varishock users out there. In order to maintain clearance of the adjusters to the coil, the adjusters must be facing the rotor (toward the outside of the car). Unfortunately, with the springs correctly indexed, one of the adjusters is hidden by a coil. You can't get the tool (allen wrench basically) in there at all. You can barely get your fingers in a little to adjust it, but since each click up (clockwise) has a little more resistance I'm not sure you could get it much more than to a setting of 6 or 7.
Has anyone else used these or have any info? If I have something incorrect I'd rather find out now.
I'm going to do the other side tomorrow if I have any garage time, along with the rear Varishocks - which are a far easier proposition.
