      Nov 2010
      Lake Placid, FL
      Cant find a crank pulley to get my Vortech V-1 to work with my LS1 swap.. Help!!
      In the process of swapping a LS1 into my 73 Camaro and was originally planning to do it turbocharged but as the parts are adding up it's become clear that it would be much more affordable for me to adapt the brand new Vortech V-1 carbed sbc kit that I acquired a few months ago. Brackets and plumbing are a nonissue I am a fabricator and those are easily build-able and there's plenty of room under the hood to me the only hurdle I'm not sure how to jump is the crank pulley were do I find one that fits? Could I adapt the existing sbc pulley to bolt to the stock LS1 pulley?? Has anyone done this? tips and tricks?? Thanks for the help guys...
      Short & sweet:
      Where to find or how to build a crank pulley for a LS1 that'll drive my V-1 Vortech Supercharger??
      1973 Camaro 550hp 406ci, turbo 350 trans manual valve body, nos 250 shot, full cage, narrowed 9" rear, 17" torque thrust IIs all about to change...
      Soon to be Force Inducted LS1/T56 swapped, 18/20 staggered Coys.. Plus a little vintage air and some tunez while I'm at it...
      Youre Going to have to go to a different balancer...
      Check out the newest Car Craft... they did a 5.3 with a ProCharger and used an ATI dampner
      1985 Monte Carlo SS- 224/228 cammed 5.3/4L80E/17x9.5 Budnik Tiller 5s/BFG Comp T/As
      2007 2500HD Silverado CCSB Duramax- 18" KMC HOSS, 285s
      2006 Corvette Coupe- Black/LS2/M6/3LT/Corsa/Callaway MP112/Nitto Invos SOLD
      2002 Sierra Denali Quadrateer-
      SOLD
      Feb 2009
      muggy midwest
      If you need a pulley made, contact the guys at March-I've had them build a few custom pieces for me with some builds I put together. 1-888-729-9070
      I had them build a pulley for me for use with a GM style serpentine system using custom brackets I designed to place a Moroso vacuum pump in place of where the smog pump used to be and I needed a much smaller pulley mated to the stock crank pulley so I could run the pump at a 4:1 ratio to keep the impellar speed down. They were a big help!
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Feb 2011
      Hills of Anaheim
      I would call A&A Corvette. They are big Vortech dealers for the Vettes.
      Jul 2009
      Sackville, NB, Canada
      ASP will also make custom pulleys. I know people who have had custom 8 rib serpentine setups made for vortech systems so they can probably hook you up.
      http://www.aspracing.com/index.html
      (sorry for the late-ish post but I thought another option may be helpful)
      Tyson
      '95 Firebird Formula: suspension + 315's
      '66 Mustang Coupe, 289
      Dec 2009
      If you decide you need to go the custom route, drop us a line. We're happy to offer advice and insight on solutions for your setup.
      Kevin
      Concept One Pulleys
      Made in the USA
      Chevy Engine Parts
    Tags for this Thread
