      Oct 2007
      Shawnee, KS
      Aftermarket Harness - Oil Level Sensor - Oil Pan
      Those of you running aftermarket harneses, are you running/using an OEM oil level sensor in the oil pan? I am looking at the cast Holley and MAST oil pans for my camaro. The MAST pan has a provision for the oil sensor and Holley pan doesn't. I also noticed that the Holley pan has a bell housing bolt hole cast in.
      Any preference on either pan?
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
      Byron, IL
      Quote Originally Posted by 67CamNKC View Post
      In for more information.
      It sounds like Holley is starting shipment on these pans this week. We don't specifically need the bellhousing bolt hole since we are going to use a 200-4R. This is the direction we are leaning in as of right now for our '88 Monte SS swap.
      Marc P.
