    Results 1 to 1 of 1
      Melbourne, FL
      67 F-body windshield pillar weatherstrip channel differences
      Most people know that there is a difference between the convert and the coupe windshield pillar post weatherstrip channel. But most also have asked what the real difference between the two is. So here is a side by side comparison between the two. The vert is top coupe bottom. AS you can see the vert is a little shorter than the coupe. By my mrasurements it 7/8" shorter. So if somone asks what the difference is you can point them here.
      Again this is for the 67 only. I'm not sure about the 68/9 versions. But I do know that the 67's are different from the 68/9's.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
