      St. Louis, MO
      2nd Gen Firebird Spring Recommendation
      OK, I have a 1978 TA, Getting ready to put the suspension together, I have used the new GW uppers with del-a-lum bushings, I rebuilt the lowers with del-a-lum bushings, boxed them in so they should be strong enough. I have used the rear global west leafs lowered 1.5" with del-a-lum bushings. My question is, I need to pick shocks and front springs. Currently I have cut 1.5 off my front springs, I put an LS1 in the car, and they needed to be cut, should I get a set of shocks and use my springs, or should I get a set of coilovers that bolt into the front stock locations. Furthermore, what rear shocks should I get. Should I get 4 that match one another, or can I go with coilovers in the front and stand alone shocks in the back. Furthermore, I am using the LS1 rear brake conversion, so I need to relocate the rear shocks at the same time, anything really big involved with this?
      John
      St. Louis, MO
      Shocks
      NOBODY? I thought with as much knowledge as everybody has here, they could help me out on this. Any help would be appreciated.
      What front coil-over type shocks are you planning on using? The bee-hive type from QA1?, or a more traditional set where the spring is fully located on the shock itself? There is no problem running a standard type shock in the rear with a coil-over up front. The issue is really more of the valving you need based upon the wheel rate, roll resistance, tires, etc. For a street car, I wouldn't sweat it too much, but you will like the freedom of an adjustable race type shock if you are going to do track time.
      I know that is really a general response, try going to nastyz28.com there seem to be a ton of second gen guys there that could offer more specific advise.
      Mark
      St. Louis, MO
      Coil Over Springs
      I was thinking the QA1's that Global West promotes, but I am not against any of them, I am just researching. Would I be better doing an adjustable shock and keeping the front spring the way it is?
      John
      Fontana, CA
      John,
      While it is great that you stated what you have and your ideas, one thing I have learned around here is to state your intentions with the vehicle and maybe even an amount you are able/willing to spend.
      With that many more people are able to help without having to guess or ask.
      Just my .02 on that.
      Nick R.
      St. Louis, MO
      Shocks, not springs
      Sorry, I put springs in the title, I meant shock absorbers. Good question and advise. As shown from the suspension parts listed, my goal is just a great handling street driver with very occasional track use both auto-x and dragracing. 95% street driven though. SO, thats why I want to know about shocks, I know shocks are a great tuning devise, but I am affraid if I pick a set of adjustable shocks, I'll adjust them once, and thats it. So maybe just get a set of good shocks, but which brand, and are shocks for lowered cars different than shocks for stock height cars. Thanks again for all the help.
      John
