      Feb 2009
      caly
      testing the waters } custom built 502 BBC pump gas mtr fresh
      any one interested in a custom built 502 pump gas mtr im thinking off going a new rout. it started life as a 502/502 it was balinced & blueprinted.oil vally all debured & polished. wisco forged pistons custom ground comp H/R cam & lifters billet timing chain.rec port heads with SS valves ty retainers nextec valve springs comp push rods.steel crank.steel rods. comp roller rockers.polished alu valvecovers.dart intk fresh powder coated.holey carb.MSD pro billet dist tayler plug wires.polished water neck. autolight plugs. milidon oil pan. hv melling oil pump.arp oil pump shaft. arp bolts.alu pullys.hy torq mini starter.carb to pan just needs water pump & drop it in& go. have build sheet & dyno sheet mtr made over 600hp on pump gas built for street strip cam is real nice sounding & the mtr cruzzes nice to. runs cool with 1 elc fan & alu 2 core rad call me for more info the mtr is still at the eng builders & will be shipped from their $5500.00 shipped for all i also have the custom built converter that was built for the mtr its a turbo input shaft ill sale for 375.00 more thanks rob (916)743-2606 [email protected]
      it was in my 66 impala ran 11.40s on mtr at over 4600lbs it is set to run a 250 shot off nitrous to
      Feb 2009
      caly
      CALL ME or E-Mail me as im not able to come up hear all the time thanks rob (916)743-2606 [email protected]
      Feb 2009
      caly
      SOLD thanks to YB
