    Results 21 to 40 of 41
      Mar 2011
      LS1 Disc Brakes Locked Up
      NEED HELP WITH PROPORTIONING VALVE AND BRAKE LINE ROUTING TO MASTER CYLINDER. SEE PAGE 2.
      Yesterday my brakes locked up after about 20-30 minutes of driving. This is the first time I have had this happen, but I just aquired the car and have not driven it much. The previous owner suspected the front brakes may have been dragging due to premature pad wear and put new pads on before I bought the car. When the brakes locked, both front wheels were too hot to hold your hand on and the right rear was actually smoking, but the drivers side rear was cool to the touch.
      I pulled the master cylinder and saw where the brake booster rod had been cut-down and two washers added between the plastic rod and the metal nipple that goes into the rod and then into the master cylinder. Installing the master cylinder with both of these washers or just one resulted in the plunger depressing some. Everything I have read is that this will cause the brake lock up I experienced. When installing with no washers, I did not feel any pressure when the master cylinder seated against the brake booster.
      So my concern is, why were these washers put here by the previous owner? Ignorance or some other reason....
      Does it sound like I am doing the right thing by removing them (shortening the rod) and are there any things I need to be concerned about after shortening the rod?
      Thanks for all the help. Threw up some pics of the rod, nipple, and washers on a shutterfly site real quick to help explain what I am talking about.
      http://eddies1968camaro.shutterfly.com/
