    Results 1 to 20 of 23
      Apr 2003
      Nyköping, Sweden
      Country Flag: Sweden
      Steering column with modern controls?
      I wonder if anyone know where to find or how to modify a steering column that give me control of dimmer lights and various speed wipers.
      It feel a little out of date with the controls that are present in my 69 Camaro, the only thing I can control from the steering column is the turn signal lights. I would like to have everything that a modern car has.
      1. Dimmer of the lights together with the turn signal on the left side
      2. Wiper control on the right side for the modern wipers like the one DSE has.
      I know that ididit has some stuff that let you have some of these controls but not all at the same time.
      Are there any other sources?
      Jan
      Jan Suhr
      Nyköping, Sweden
      1969 Pro touring Camaro Z/28 LS1/T56
      Scandinavian Pro Touring Forum protouring.se
      Jul 2007
      Olathe, KS
      I ended up shortening a 4th Gen F-body column about 3-4 inches, and adding the 1st gen bracketry to attach it to the dash. It was really simple to do. The turn signal, wipers, and dimmer are all on one stalk on the left side. If you're inclined, you can even find one with steering wheel audio controls
      The internal diameter of the shaft is a hair over 3/4". I welded a short stub of 3/4" DD shaft to it to connect my steering gear. I got the idea from CamaroAJ, who's done a few of them this way.
      You'll have to make a few wiring changes to make it all work, but I can provide a schematic of the original column if you go down that route.
      Nothern California
      search for the name birdsandbowties he builds columns with GM parts https://www.pro-touring.com/showthre...ilt&highlight=
      Guy S.
      68 Camaro LS1, T56, Forgeline WC3
      69 El Camino BBC 4spd A/C Cruise SOLD
      2012 Dodge Crewcab Diesel 4x4
      Cornettsville, ky
      what about a 66 down car?
      Feb 2006
      Idaho Falls, Id
      I would think a 3rd gen fbody column would work better than a 4th gen and probably be closer to the right length and the controls are pretty much the same and 3rd gen columns have splined shafts. I haven't tried it yet though but I plan on it at some point.
      Traven
      Jul 2007
      Olathe, KS
      You're probably right about the 3rd gen column fitting better. I just happened to have a 4th gen column from the TA I parted out for my drivetrain.
      With that said, I think you'd still have to shorten the 3rd gen column, which would get rid of your splines.
      Feb 2006
      Idaho Falls, Id
      Quote Originally Posted by Rhino View Post
      Yeah that could be true. I've got a 4th gen one from my donor and a 3rd gen TA so I'll have to measure both of those and the one in my 67 to see how long they all are.
      Traven
      Aug 2003
      We can do wiper control on the tilt lever and high beam on the turn signal with IDidIt.
      Oct 2007
      Shawnee, KS
      Ryan,
      What steering wheel are you using with this setup? Can an aftermarket wheel be used? And what are you doing for an ignition key setup?
      Shannon
      67 Camaro - Finally getting to BUILD it.
      Camaro Build -> HERE
      Our Drag boat blog and videos HERE
      Jul 2007
      Olathe, KS
      I haven't really decided yet, but just about any aftermarket wheel can be made to work with a column adapter. For mockup I'm using the stock wheel.
      Originally I wanted to keep the ignition on the dash, but once I got to looking into all the work involved I don't think it's worth moving it. I'm using the entire wiring harness from the '02 TA and will likely keep the stock TA ignition setup along with it's VATS system.
      If you're interested in doing the same, let me know. It's really simple to do and the columns can be had for next to nothing.
      Apr 2003
      Nyköping, Sweden
      Quote Originally Posted by ProdigyCustoms View Post
      But how do you do if you don't want tilt? I guess the tilt is still working on the setup you propose.
      Jan
      Jan Suhr
      Nyköping, Sweden
      Aug 2003
      Yes the tilt is still working. I do not know of any non tilt column with the features you want.
      San Antonio, Tx
      if your handy with a welder and have some fab skill than the 4th gen column swap is simple.
      Instagram: CamaroAJ
      Dublin, CA
      The turn signal assembly from late 80s to early 90s GM columns can be installed on the 70s columns. There is a little bit of widening of the plastic cover required. This will move the dimmer up from the floor and give you wiper controls on the lever. The dimmer wiring hooks right up, but the wiper will take some modification.
      Brent
      1971 Camaro, LT1, 4L60E
      Jul 2007
      Olathe, KS
      The wipers are another thing that's pretty cool about the modern column. With a little more fab and some wiring it's pretty easy to do an install similar to DSE's wiper unit.
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by barno68 View Post
      I had that issue with my 82 TA. They changed the setup in 84 and I put an 85 column in my car. I had to rewire the wipers bit. So an 82-83 3rd gen column might have the same basic setup as older cars. I pretty sure my 82 had the same wiper motor my 77 has now. Whatever that info is worth.
      Scott from NJ.
      Vent Windows Forever! ...
      So. Cal.
      I have an 84 Pontiac steering column in my 62 nova. Love it. I also have a painless wiring harness. The plug from the painless harness plugged right in and I have all the functions of the column. Keyed ignition, high and low beams, turn sigs, and variable wiper controls, even the hazard button and horn. Simple swap. Along with a grant steering wheel. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      Jul 2009
      Cypress, TX
      Can the wiper controls be modified to operate the DSE wiper unit? Also, how do you handle the VAT when installing in a first gen?
      Jul 2009
      Grand Rapids, MI
      Is it possible to get a column with these features PLUS cruise? Too much to ask...
      Will Ellis
      Build Thread
      Apr 2003
      Nyköping, Sweden
      Quote Originally Posted by terrydmorgan View Post
      That wouldn't be to much of a problem. I made my own control for the '01-'02 Camaro wiper motor, the same kind as DSE uses, and it would work with the wiper control from a Gen 3 steering column.
      The VAT can be disabled in the ECM-unit.
      Jan
      Jan Suhr
      Nyköping, Sweden
