    Results 1 to 10 of 10
      Melbourne, FL
      What Wilwood caliper is this
      Attachment 44905Can someone tell me about this caliper?? It supposed to be a Wilwood single piston GM D52 style caliper. But I can't seem to find anything on it.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Feb 2010
      Central NJ
      Check Wilwoods website... I remember seeing them on there... I believe its a circle track application for stock classes... Howe makes a similar product.
      hope this helps...
      -Sean
      Coronado, CA
      It looks like the front Wilwoods on HMMWV's.
      Nope. See edit.
      Last edited by go-fish; 02-24-2011 at 11:05 PM. Reason: Well, maybe not. Just found a pic of one.
      Johnny C.
      Melbourne, FL
      Quote Originally Posted by sr73bu View Post
      hope this helps...
      -Sean
      Thanks. I'll look again. But I didn't see anything on my previous look. I assume they are probably an older discontinued model. But may be better than my stock cast iron calipers in the short term until I can buy the newer D52 calipers. I'll send a pic to Wilwood and see what they say also.
      Feb 2010
      Central NJ
      I have Wilwood's new dual piston Caliper upgrade for d52 calipers... everything bolted right up and the quality is very,very nice.. i went with the (2) 2" piston option. Check my build thread for more details (link below).
      -Sean
      Melbourne, FL
      -Sean
      Those are what I'll probably switch to in the long run. I know someone who has these for basically free. So if they are any better than my stock ones I'll use them until the car is finished then switch to better calipers.
      Bolivar, MO
      Speedway motors sells them. They are listed under the hot rod section. Here is a link.
      http://www.speedwaymotors.com/Wilwoo...pers,1346.html
      They also carry the came caliper for metric 78 and up.
      Tim.
      Melbourne, FL
      It could be the smaller version of the GM III since that has a 2.38" piston. But the pic is different. I'm going to stick with my stock calipers since the piston is bigger than these. But after the project is all done I'll probably switch to the new D52 calipers for the front.
      Bolivar, MO
      Honestly until I read this thread I did not know about the D52 calipers. I have nice but cheap setup on my rear that I will use these instead of the GM3. Thanks for posting it.
      Jun 2006
      Katy,TX
      Thee look like an old version of Wilwood's aluminum GM caliper.They had some rigidity issue when pushed hard by the circle track guys. In fact many in classes that required a GM style caliper just used a lightened(cut up) cast iron one.
      Many circle track classes even some of the late model asphalt cars require GM type calipers, why Howe came out with a dual piston aluminum one years ago..
