Results 1 to 8 of 8
- Jan 2011
- Middle TN
- 19
I know the thread is a few days old but I figured I'd put my 2 cents in.
The EFI connection link is your best bet to be able to use an LS computer. Most of the parts to convert to 24x will come from the Vortec 350s IIRC. I looked into that for my TPI IROC before I decided on a motor swap. You'll need a dizzy, a crank position sensor, new timing cover, and a few other parts from a Vortec motor that I can't remember off the top of my head. And of course you'll need a TPI fuel system since it's standard cooling. From there you'll need the LS coil packs, a means to mount the coil packs, plug wires, etc. There will also be some wiring that you'll need to do if I recall correctly as well. It's been a while since I was looking into it but I hope that points you in the right direction. If you have any more questions you can PM me and I'll dig up all the info that I have from when I was looking into it. I can also help with the TPI setup as well since i'm pretty familiar with those motors.
Hope this helps you.73 Z28 Camaro. Bone stock except for TKO-600 road race 5 speed.
