    Results 1 to 9 of 9
      Jun 2010
      spokane
      Halfbreed update wheels and brakes
      Finally got the brakes mounted up used kore3 hybrid brackets for the 355mm rotors very well made product by the way . Installed ls1 rear brakes with drilled rotors . Got 19" wheels 8.5 front 9.5 rear with 20mm offset installed 1/2x20 screw in wheel studs . I am still bending tubing and doing the flares . I am doing bubble flare and standard so i can use any off the shelf brake hose for camaro and vette . Its a lot of work but the old brake tubing was rusted and aged so its worth it . Spent all day in the driveway with a pressure washer cleaning the underneath of the car . Used degreaser and jasco rust convertor that stuff works great used por 15 on the entire underside of car . Its not a show car just a clean daily driver . I have been waiting 2 weeks on my sc&c stage 2 plus kit .
      san diego
      Birmingham, AL
      What brand of wheels are those? They look great with those brakes sitting behind them.
      Stephen
      Jun 2010
      spokane
      Not sure about wheel brand bought them from a guy that had got them for his bmw 5 series . They fit the wheelwells perfect . I measured the pattern between gm and bmw the differnce is less than the tip of a pencil divided by 2 i used hub centric rings to center them 70.5 to 74.1 mm and used 1/2 x20 screw in arp studs .
      Jun 2010
      spokane
      Next step is hyperco springs front 5x12 700lbs with spacer and rear 5.5 x11 175lbs with pigtail on one end a spacer on other and hellwig pro touring rear sway bar .
      Jun 2010
      spokane
      Rolled halfbreed out of garage for pics
      Its in mock up phase still .
      looking good! nice stance!
      Jun 2010
      spokane
      There are more pics at this link http://www.mypowerblock.com/profile/TimStark
      Jun 2010
      spokane
      Got my sc&c stage2 plus kit and ub machine lower control arms
      Started install also have black magic 9.5x5 750lbs front springs with adjustable spacers and 11x5.5 175lbs rear springs . The pic of car is before it looks like final ride height is about an inch lower . Here is some pics.
      Tim
