    Results 1 to 20 of 26
      Feb 2011
      Chicago
      New from chicago (Roy)
      Hello guys my names is roy i am installing a ls1 in my 1971 chevelle it has been a real blast i have got alot done but it has turned into a restoration more then a swap i have been reading alot of your post i hope mine looks as good as everyboby elses thanks for looking. roy
      Feb 2008
      Chicago
      Welcome Roy, I'm from the NW side of Chicago.
      Ken B.
      65 GTO
      67 Firebird vert
      Feb 2011
      Chicago
      Thanks new to this it is the first
      forum i have joined this site is great!
      Feb 2011
      Chicago
      New from chicago(Roy)
      Well got a little done i removed the old tank and wire wheeled under the tank found a surprize the oringal build sheet NICE! I put two coats of lizard skin, I am trying to quiet the fuel pump which is in the tank.I have a lot of old parts that i am having sand blasted and powder coating,Man i did not think of the huge dust strom when the wire wheel hit thank god for face shield and a dust mask!!
      Erie, PA
      Welcome!
      I am in the Western Burbs, where are you?
      Andreas
      www.fgmcc.com
      Feb 2011
      Chicago
      I am in bucktown in the heart of chicago!
      Feb 2011
      Chicago
      ls1 swap
      Well got a little done in the last couple of days even had my son in on the action got the rear end wire wheeled painted and installed the rear brakes i hope in the next couple of days to get the tank and fuel lines in then the rear end!!!!
      Feb 2011
      Chicago
      Ls1 swap
      well a i have a update i got a little more done i got the tank and fuel lines run into place also installed the rear end like i said in my previous post it turned into a restoration then a swap no really big surprises no rust just a little service rust and a lot of dirt. well next is the motor!!!
      welcome aboard! nice project! you want to start a build-thread in the "project updates section"
      Dec 2009
      Naperville, IL
      Nice project. You've got to be one of the only guys building a car Downtown-- not a lot of garage space down there... and not a lot of parts stores around that I have noticed. I'm from the Western Burbs as well.
      1966 Caprice - L92/4L80e, Ridetech/Hotchkis Suspension
      Build Thread: https://www.pro-touring.com/showthre...Big-Black-quot
      1989 Camaro Iroc Z G92 5-Speed (one of 300 as optioned). Bone Stock.
      May 2007
      Mooresville, Indiana
      Excellent! I'm a Chevelle guy also and not too far away... Just a little southwest of Indy.
      Tom
      Feb 2011
      Chicago
      Yes you are right not much room at all but i am making it ,I have been ordering from s&p mark is great the guy will answer any question and walk you through any problem ! I have also ordered from the parts place it is a little pricey but i think it is worth it! I got my computer in to day and some of the wiring it is all the little stuff that is eating up a lot of time i will post some pics of what i got done.
      Feb 2011
      Chicago
      Tom (I hope that is your name) do you do the chevellabration this will be the first time i am thinking about going if so any pointers before trying Thanks Roy
      Feb 2011
      Chicago
      ls1 swap
      I got all my stuff in,my wiring harness ,computer alt. pwr steering ac,from s&p the kit was pretty easy to install all detailed instructions i need to find out which fan set up to use not really sure yet i have been reading the forum and every body is running something different any suggestions Next to do on my list is to reinstall the front end!!
      Nov 2004
      The original home of Nickey Chevrolet
      I grew up at Ashland/Division
      Feb 2011
      Chicago
      i was just through there today are you still in the area?
      Feb 2011
      Chicago
      trying to post pics bigger can't seem to figure it out!
      Feb 2011
      Chicago
      I finished up the wiring today still have to put the front end together and finish the wiring to the head lights i ordered the drive shaft and my exhaust i will post pics soon
      May 2007
      Quote Originally Posted by scemeca View Post
      Yep, we've been to CB a handful of times and will be going again this year.
      Tom
      Feb 2011
      Chicago
      ls1 swap
      Well i am getting close still need to do a few loose ends yet i have a couple more wires left i am working in a 2 1/2 garage so i need to get the car on the ground so i can get to the drivers side better here is a couple of pics to show what i have done!
