    Page 4 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 14 ... LastLast
    Results 61 to 80 of 298
    1. #61
      Very cool build. I almost went with that wheel choice as well. Love the look. Theres a similar build on tffn. My next step is paint and body and was considering the gold tint for my wheels as well. I like the gold tint, reminds me of old european race cars for some reason.
      Money, girls and cars...big ol' long cigars!
      1964 Mercury Comet
      90's 302HO, F303, Vic Jr, AFR 165's, 650DP, full roller, full MSD, WC T5
      18x8 245 up front, 18x9 275 out back
      KYBs, sway, 620 coils, stiff leafs relocated inboard
      13" Late Model Cobra Brake Setup
    2. #62
      Texan Back in Texas!
      I rebuilt the narrowed rear and painted it up to look all nice and pretty. Only kicker is that I will have to tear it back down to isntall the Wilwood parking assembly, oops.
      1965 Falcon Hardtop
    3. #63
      Work had me out of town and then life has just been kicking my butt lately so no time to get the rear brakes on. I did unpackage them to make sure all the bits are there and also realized I have to pull the axles back out to slide ont he parking brake assembly. Here are a couple of pictures of the brakes. They are the new two piston floating caliper kit from Wilwood, 12" zinc plated drilled and slotted to match fronts.
      Maybe this weekend I will be able to get these on and actually set the car down on all four wheels, first time since it went up into the air a year ago.
      1965 Falcon Hardtop
    4. #64
      Feb 2011
      Indpls, IN
      You could always take this time to order a nice machined aluminuf differential cover. :-)
      Looks great man!
      I placed a order for my TCI 4 link kit two weeks ago. Thanks! LOL!
      Steve
    5. #65
      Thought about the diff cover, but it is more of a dress item than performance in my case (won't be running massive power) so I figured the $150 was better spent elsewhere. It is an easy swap out later if needed.
      1965 Falcon Hardtop
    6. #66
      Nov 2007
      Lafayette, LA, USA
      That is a very sweet Falcon. I am subscribing.
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
    7. #67
      Quote Originally Posted by fordsbyjay View Post
      Thanks!
      1965 Falcon Hardtop
    8. #68
      Jan 2010
      SLC. UT
      Sweet build! Great wheels, the err look especially beefy with the dish.
      Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
    9. #69
      I was able to get the Wilwood kit installed late last week. Really nice kit for the rear, especially for a floating caliper. The amazing thing is that this kit is made for the big bearing Ford rear and yet it bolted up to my explorer rear without modifications, like the kit was designed for it. This kit has full parking brake function and uses the 12" rotor with the two piston D154 GM caliper. It matches the fronts perfectly although they do get lost in the deep dish of my rear wheels. Over all I am thrilled with the kit and can't wait to get this thing out on the road and test out the full Wilwood package.
      Here are a few pictures of the kit installation.
      1965 Falcon Hardtop
    10. #70
      Finally on the ground!!!
      Huge moment for me.... FINALLY HAVE IT SITTING ON ALL FOUR WHEELS!!!! First time it has been back on the ground since a year and a half ago when I rolled it into the garage to begin the tear down. The pictures do not do it justice, in my small gagrage I could not get a really good angle to show how low and wide it looks. I love it!! Also love how fat the rear tire looks under the small body of the Falcon. In final form the front will be about another half to inch lower, the rear is sitting perfect.
      Next up I will get it up on the cribbing and build subframe connectors and other reinforcement for the chassis. I noticed just how much of a wet noodle the chassis is when setting it down on the ground, man does it flex around. Then I will move on to replacing the floor pans and shoehorning in the 3v 4.6 and TR3650.
      I have to shout out a special thanks to Jason and TCI for the trick suspension and the awesome customer support, I decided to modify just about every part they sent me, in hind sight I should have had them just send me everything as an unwelded kit. I ended up cutting most things apart and then reconfiguring it to fit the car and accomodate the wide tires.
      1965 Falcon Hardtop
    11. #71
      Jul 2008
      ohio
      looks killer.....makes me want to go get this
      http://columbus.craigslist.org/cto/2877909011.html
    12. #72
      Hold out for a hardtop, sleeker body style.
      1965 Falcon Hardtop
    13. #73
      Feb 2011
      Indpls, IN
      Craigs73, That looks to be pretty clean for a Midwest car. Maybe not as sleak as a HardTop. But still nice.
      LowFast, looks great man. Can't wait to kit my kit now. I got the 8" style coilover mounts with mine. I'm using a 8.8 right now. My car is in storage at this time.
      What is the diameter of the Explorer 8.8 axle tubes?
      Thanks,
      Steve
    14. #74
      Quote Originally Posted by Jetfixr320 View Post
      Thanks,
      Steve
      Officially I think it is supposed to be 3.25" Mine was at 3.3" using a pair of calipers to measure. You will have to modify the 8" mounts to work on the 8.8 axle. Unfortunately TCI does not make a bracket big enough to slide on to an explorer 8.8. The good news is that the explorer has some beefly tubes and axles, more so than the mustang 8.8, that can handle just about anything you throw at them.
      1965 Falcon Hardtop
    15. #75
      Feb 2011
      Indpls, IN
      Ok, Thanks for checking that.
      Steve
    16. #76
      WOW looks great! love the wheels!!
      Nov 2010
      Mooresville, IN
      Lowfast, love those wheels!!! I've been looking for some minilite clones for awhile in an 18x12 and the ET3s are the answer to my problem. The car is looking great!
    18. #78
      I love them, the quality is awesome, but be aware the 18x11's in a two piece were a pretty penny. Took three barrels to get the offset that I wanted, ended up about $650 bones each, ouch. But all that being said I love them and would do it again, they give a perfect old school trans-am look.
      1965 Falcon Hardtop
    19. #79
      McKinney, TX
      This is a good looking car in person. Nice work!
      89 Mustang "Box Wine"
    20. #80
      Thanks, it was good to meet you and best of luck on your rear-tubbing.
      1965 Falcon Hardtop
