    Results 1 to 14 of 14
      Woodbine, MD
      Do AN Wrenches work??
      Before I invest in them I would like to know if those AN Wrenches really work? Do they not mark up the an fittings??
      Douglas Lutes
      1988 Monte Carlo SS
      Aug 2006
      San Francisco, CA
      My an10 wrench does slightly mark up the fittings because it is slightly oversized for some reason. It does much better than regular wrenches though, and the relatively short handle is much more maneuverable.
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Indiana
      Yes they work unless you try to overtighten the fittings, then there's a chance they'll make marks.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Oct 2008
      Durham,NC
      Whata about what AN wrenches do you guys recomm for $? This might help alot of guys out, by knowing what to get right off. Brandon
      Indiana
      Quote Originally Posted by brans72 View Post
      This is the set I bought from Summit.
      So far they've worked good for me!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Rockford Illinois
      It cost very little for the material to make them and if you have access to a mill it makes it easier but regular woodworking tools can achieve good enough results if not perfect results. A router will machine aluminum very easily.
      Oct 2008
      Durham,NC
      Jim do you mind shring more info of using a router with aluminum? I hve always been curious as seen stuff posted etc about they made it but never seen details on what to use etc nd wanna know lot more!!!!! Brandon
      Lawrenceburg, TN
      we sell AN wrench's at the shop, but really when we assemble our own set ups or those for other people we just use good crescent wrenches and take your time
      I use ordinary short wrenches. No marks if you work carefully. I've always wanted an AN set, but never could justify the cost.
      ​John Parsons
      Henderson,NV
      I like my Jegs AN wrenches for tightening and loosening fittings. I use a crescent wrench during asssembly of the hose ends. I don't mind a little wear and tear on the fittings. It just means you actually use your car and work on it.
      Todd
      Feb 2008
      Denver NC
      I bought a set of XRP wrenches... but rarely use them and I work with AN lines daily.... I have a set of Snap On mid length wrenches that I prefer... basically dont be an idiot and have a little common sense and you'll be fine.Also Knipex plyers work very well too... they have smooth jaws and clamp parallel on the fitting and leave no marks
      Rockford Illinois
      A 1/3 to 1/2 hp router and a good router table and a straight largest diameter carbide bit you can put in and be able to do the job and cover the sides of the material is all you need. Leave your pieces in a block and do your slots for tool and then cut out the wrench shape after you are done with the open wrench area. Go very slowly and you can even trim out the area with a band saw to reduce the amout you will remove. Just use the router to trim up and get the dimension you need. You might even drill and tap a hole and put a bolt in to hold on to the the part if you want.
      Just be careful and use common sense and you will be all right, Always wear a face shield and some thing to cover you arms as the aluminum shaving can be hot sometimes.
      Working with aluminum the same as a really HARD wood is comparable.make sure your tools are the sharpest and use WD 40 as lubricant if needed for the bit and don't go too slow or too fast, let the tool do the work.
      You must use carbide tooling with aluminum !!!!
      Nov 2007
      Lafayette, LA, USA
      AN sizes seem to vary depending on brand. I have two different sets of AN wrenches and I use large crescent wrenches instead. They have a lot of surface area and don't scratch unless you really lean on it. You always try some tape on them but I never have. Personally the two sets of AN wrenched I have was a waste of money I would suggest not to waste your money.
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
      Central NJ
      I've used Summit's wrenches without an issue. Cheapish and effective.
